Old 05-15-2008, 08:12 PM   #1081
Alfie's Avatar
Trader Rating: 17 (100%+)
Send a message via ICQ to Alfie
You may want to try 35T pinion?
I'm not sure. Is your spur 100T on 64 pitch?
What's the turn of your Reedy's Stock Star?
Alfie
Originally Posted by Nugget 1 View Post
reedy stock star 008 rubber 50w 100L
F103KŠ • F104PRO • Universe • Spektrum • GTB • GTX • Trakpower • Orion
Retired Fleet: DDM • F103GT-R™ • F103LM TRF • F103LM • RC10L3 Team Touring • YR4M2 Type J PRO • YR4M • YR-F2 SP • Boomerang • Mountaineer • JPS • Clod • Bullhead • TLT-1 • Avante 2001 •
Alfie is offline   Reply With Quote
Old 05-17-2008, 07:54 AM   #1082
SpeedFreak162's Avatar
Hey Guys a couple quick questions if anyone minds answering. I'm currently still building the car. While mounting up the front sway bar i find its very easily hitting the axels with just a bit of suspension movment. i know the links are adjustable but it doesnt seem like theres gunna be a lot of threads holding the 2 ends together if i lengthen them up. And i need a baseline gearing setup
Im running a Novak 3.5BL GTb speed controller and Orion 3200 lipo with rubber tires. Any help would be great
Donald "Ducky" Howe
Vechiles: Kyosho Ultima RB6 | Kyosho Ultima SC-R SP | Kyosho Ultima RT5 | TLR SCTE 2.0 x2 | Darkside Motorsports Ignitor | KSKT SparK | CRC Gen XI NASTruck | "Next"
Equipment: Viper R/C | Spektrum | Trinity | Turnigy | J-Concepts | AKA | Pro-line
Tracks: Gallimods | RCHR | Pin Shop | Wocott
SpeedFreak162 is offline   Reply With Quote
Old 05-17-2008, 08:07 AM   #1083
Build it the way they say to in the manual and once you have all the components on the car and it is set-up to go on the track they will not touch. Xray does have tight tolerence but there is always room
Joe
Real men race MODIFIED!!
JoeGlover is offline   Reply With Quote
Old 05-17-2008, 08:58 AM   #1084
Nugget 1's Avatar
i got a 114 with a 35 64 pitch
Nugget 1 is offline   Reply With Quote
Old 05-17-2008, 12:37 PM   #1085
Nexus Racing's Avatar
R/C Tech Elite Subscriber
On my Novak 3.5 system, I tend to run over 10.0 if running the standard 12.3mm rotor, and under 10.0 if running the 13mm rotor. I have not run the standard rotor in my 3.5 for quite a while, though.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 05-17-2008, 01:14 PM   #1086
Thanks guys,
Joel, Yeah i see wat ur saying, it just seemed so damn close but i guess once everythings setup ill be alright. just wanted to be 100% sure
Donald "Ducky" Howe
Old 05-18-2008, 06:48 AM   #1087
Default QUESTION
I bought a '008 a few months ago and race in the stock class at the local track. I'm currently running a orion 3200 lipo and novak GTB/17.5 setup. One guy that has the same setup in an original T2 said 92T spur and 44-48T pinion. The problem I'm having is that I can't access the motor screw closest to the rear bulkhead with this necessary gearing. Suggestions would be greatly appreciated. Thanks
Joseph D. Jones (DAD) - Best Racing buddy and father ever! Gone but not Forgotten
Team GB Old Skool
xrayzone is offline   Reply With Quote
Old 05-18-2008, 07:05 AM   #1088
Trader Rating: 16 (94%+)
xrayzone: Are you using Spur gears that have the large holes within the spur gear itself, like the stock Xray, PRS, or RW spurs?
If not, this is what you need:
kn7671 is offline   Reply With Quote
Old 05-18-2008, 05:25 PM   #1089
noline's Avatar
Hey Guys I just picked up a Losi 10.5 and a Hacker 10.5 how would you gear these motors with a 100 spur. Im running on a 100x50 asphalt track with rubber tires any help would be great.
noline is offline   Reply With Quote
Old 05-19-2008, 06:04 AM   #1090
Hi guys, I need your help.. when I use my new 008 I use a lot of angle effect, but i don't know the effect of ackerman in the quick saver.. everyone can help me?
Ryo Saeba is offline   Reply With Quote
Old 05-19-2008, 07:43 AM   #1091
YAH
YAH's Avatar
Trader Rating: 77 (100%+)
Questions?? Can Lipo fit
Can anyone please tell me is there any mod to the chassis required for T2 008 to git Lipo and using the battery strap?
The only Surviving Active Life membership of the Smash 'EM! Racing Team, WA's Home of Fun in RC Motorsport, has retired!!
2013 WCMRC club champion - VTA and Mini.
YAH is offline   Reply With Quote
Old 05-19-2008, 11:55 AM   #1092
No Chassis Mod is required. You might have to shim up the battery strap posts to fit the height of your LiPo though. The tallest LiPo you can fit on the '008 w/o spacing up the top deck is 22.5mm. The only mod required will be to the plastic Xray battery stops that screw onto the chassis.
Old 05-19-2008, 12:00 PM   #1093
Trader Rating: 198 (100%+)
You can fit an SMC 5000 pack in the 008. Just do not place it under the top deck. It will hang off the chassis about 1/2 inch. But that is OK. Just tape it in good.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 05-19-2008, 03:49 PM   #1094
What is "angle effect"? Are you referring to the angle in the steering linkages to the servo saver? The adjustment will depend on rubber tire or foam tire? Also, download the Xray T2 setup book for a good explanation of each part of the suspension of how it effects the car.
Old 05-19-2008, 03:58 PM   #1095
You will need a pinion somewhere between 29 to 32 tooth pinion.
