Old 05-09-2008, 09:42 AM   #1066
dal bains's Avatar
Trader Rating: 35 (100%+)
well find out in 2 weeks!!
RCAMERICA-XRAY-HUDY
dal bains is offline   Reply With Quote
Old 05-09-2008, 10:32 AM   #1067
Send a message via MSN to mark34 Send a message via Yahoo to mark34
Just moved to an xray from Tamiya and the car was awesome on asphalt here in the uk,never thought I would find a car as good as a Tamiya. Ran almost kit setup and the car was dialed. Just one thing which way on the servo saver do you move the settings to get less steering
Mark
Yokomo BD
CEFX C12
Powered By Demon Batteries and GM Brushless and 2 thumbs
Mark Ashby
mark34 is offline   Reply With Quote
Old 05-09-2008, 12:17 PM   #1068
Trader Rating: 19 (100%+)
Send a message via AIM to teammidget lilB
Mark
Not answering your ? really but I had the same issue to much steering with the box set up. Try just going to softer springs in the rear or harder in the front. Hope this helps...
Bryan
Bryan "Lil B" Ford
U.S. Army @ Camp Humphreys, South Korea
teammidget lilB is offline   Reply With Quote
Old 05-11-2008, 02:30 AM   #1069
jonas_h's Avatar
could someone give me a setup for a tight low-grip asphalt track?
with basic asphalt-setup i have no steering
i am driving a 9,5T BL with 5 cells, which is compareable to your 19T class.
XRAY T2 '008
jonas_h is offline   Reply With Quote
Old 05-11-2008, 04:00 AM   #1070
RCSpeeder's Avatar
Try this..
1. Front 4.5 mm height 6mm droop. 3 holes in shocks.
2. Rear 5mm height 5.5mm droop. 3 holes in shocks.
3. Top Deck less 2 screws on rear.
4. Bottom deck less 2 screws on front (last 2 holes)and less 2 screws on rear (middle).
5. Servo Saver ackermann on No4.
Hope this helps.
RCSpeeder is offline   Reply With Quote
Old 05-11-2008, 07:34 PM   #1071
noline's Avatar
Hello There I've just recently picked up a 08 T2 what are you guys gearing for a 13.5 BL and a 10.5 BL? Im running on a 100x 50 asphalt track with rubber tires any help would be greatly appreciated.
noline is offline   Reply With Quote
Old 05-11-2008, 09:52 PM   #1072
adamge's Avatar
noline, a 100t spur and a 44t pinion is a good place to start. You'll want pinions in the 40 to 50t range to fine tune.
-Nietzsche
Old 05-11-2008, 10:54 PM   #1073
J.Filipow's Avatar
Trader Rating: 15 (100%+)
For those motors, you'll probably want a few spurs smaller than a 100. I recommend a 90 and 92 spurs for that size track and pinions 45-55...FDR for 13.5 somewhere in the 4.0-4.2 range would be my starting point.
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 05-12-2008, 02:22 AM   #1074
alecladanga's Avatar
hi guys
just wish to ask a newbie question - will the motor mount bulkhead of the 008 fit the 007?
Thanks in advance
Old 05-12-2008, 02:52 AM   #1075
Alfie's Avatar
Trader Rating: 17 (100%+)
Send a message via ICQ to Alfie
You may want to try heavier shock oil because with light shock oil + harder spring, the car will bounce too fast. The stock springs are alright and advise that setup to be done from there. Change the springs accordingly, should everything else failed.
Shock oil will remove some sensitivity from the steering action.
My current setup is:
40wt Trinity Shock Oil
3-Hole Piston
Sorex 40R (on all 4)
Ackermann on step 1
Front Shock mounting (on shock tower) on the 1st hole from centre of car
Rear Shock mounting (on shock tower) on the 4th hole from centre of car
Stiffest Flex (all screws on)
Front Multi-Diff
7.5R Novak BL/Orion 3600 Lipo
My current setup has quite sensitive steering response and understeers a little. I'm going to do EITHER the 2-hole piston on the front or changing the front shock oil to 50wt, as my 08 is rolling too much, though it's pretty good for chicanes and technical track. Just never get enough time to do those changes.
If you really don't need so much steering and don't have the time to do setups and such, then try this: installing the Hudy Aluminum Front Chassis Brace. It will make the car understeer and easier to drive.
I have tried that Front Brace on my 08 and didn't like the understeer, but it sure is easier to drive!
Hope it helps!
Alfie
P/S: I'm selling the brace to someone who needs it more. It's only used for less than 2 minutes on my '08, please make offer through PM. Thanks!
Mark
Bryan
F103KŠ • F104PRO • Universe • Spektrum • GTB • GTX • Trakpower • Orion
Retired Fleet: DDM • F103GT-R™ • F103LM TRF • F103LM • RC10L3 Team Touring • YR4M2 Type J PRO • YR4M • YR-F2 SP • Boomerang • Mountaineer • JPS • Clod • Bullhead • TLT-1 • Avante 2001 •
Alfie is offline   Reply With Quote
Old 05-12-2008, 02:53 AM   #1076
Alfie's Avatar
No.
Originally Posted by alecladanga View Post
hi guys
Thanks in advance
Old 05-12-2008, 02:55 AM   #1077
thanks Alfie
Old 05-15-2008, 07:28 AM   #1078
Nugget 1's Avatar
hey i got an x-ray i cant get the gearing right on it can any one help with that?
Nugget 1 is offline   Reply With Quote
Old 05-15-2008, 07:30 AM   #1079
turd ferguson's Avatar
Send a message via AIM to turd ferguson
What motor? Speedo (if brushless) Car? Tires (foam or rubber?) Track size?
TrakPower, Speed Passion USA, Pro-line, Stickit1 Racing, LiveRC.com
turd ferguson is offline   Reply With Quote
Old 05-15-2008, 08:10 AM   #1080
Nugget 1's Avatar
reedy stock star 008 rubber 50w 100L
