Xray T2'008
Old 02-28-2008, 04:19 AM
  #916
Default Final Drive Ratio
Hoping for some help,
I need some suggestions for a FDR, to suit te following:
T2 008,
5cell, B/Less 3.5, on a REAL big outdoor track. This club is a 1/8 nitro club norally, lap times for mod usually 17 sec on a good day!
Cheers
Simon
Bluey_74 is offline
Old 02-28-2008, 03:44 PM
  #917
NOOB-SMOKE's Avatar
T2 008,
Cheers
Simon
Hi mate
Start around a fdr of 8.6 to 8.0 and then check the motor temp and gear accordingly.
hope this helps.
cheers!!
Well done teemu awsome drive
NOOB-SMOKE is offline
Old 02-28-2008, 11:55 PM
  #918
Dan the Man's Avatar
Trader Rating: 40 (100%+)
Anyone got an idea on the maximum FDR I can run with a Tamiya Sports tuned, (87t spur with the upgrade pulley kit) without cooking the motor?
Thanks!
Dan the Man is offline
Old 02-29-2008, 01:56 AM
  #919
Trader Rating: 31 (100%+)
Well I just got back on the Xray train, bought myself a t2'008. Gunna be running 19T on ashpalt... any tips or tricks I should know about before I start the build? Last Xray that I built was a T1FK, so I'm hoping for the same ease of assembly and use.
$$$... is offline
Old 02-29-2008, 05:12 AM
  #920
Trader Rating: 16 (94%+)
Yes, buy some extra belts. The new split pulley design on the layshaft is eating the belts more quickly than the previous single-sided double pulley design. And since the Rubber cars use even smaller layshaft pulleys, the belts are unraveling even quicker.
Other than that, the '008 is just as robust but better than all previous versions.
Enjoy.
kn7671 is offline
Old 02-29-2008, 12:03 PM
  #921
wunja is offline
Old 02-29-2008, 02:07 PM
  #922
Even if true, which we don't know, who cares. Some of the best ideas in the world are borrowed ones. Where Xray succeeds, others fail.
Another point here, if Xray is guilty of copying, than I guess all other brands other than Novak are guilty of copying them. Novak was the first to produce sensored brushless motors and ESC's for the use in RC Cars. Also the first to include color bands to identify motors, the first to offer sintered rotors, the first to produce a Brushless and Brushed capable ESC, etc, etc, etc.... That means LRP, Speed Passion, Trinity, Orion, Peak, etc.... are all using borrowed, COPIED, motor and ESC technology.
kn7671 is offline
Old 02-29-2008, 06:35 PM
  #923
Piyo Piyo's Avatar
Thanks!
Try 5.5 FDR. At least that is what I used when I play in last year TCS with TT-01 chassis. Balanced power.
Piyo Piyo is offline
Old 03-03-2008, 09:25 AM
  #924
RC MARKET's Avatar
Trader Rating: 12 (100%+)
some parts was release
1.1mm 1.3mm anti-roll bar
alum. chassis brace
multi-diff
Attached Thumbnails Xray T2'008-xr-302054.jpg   Xray T2'008-xr-302483.jpg   Xray T2'008-xr-303481.jpg   Xray T2'008-xr-305104.jpg
RC MARKET is offline
Old 03-03-2008, 09:28 PM
  #925
Has anyone had problems with the front universal drive shafts on their T2'008? mine sound as if they are binding every time they spin, only when the wheels are turned
I've pulled them out, taken them apart and nothing obvious... everything else on the front has been checked and no binding at all, just the chattering driveshafts.
The car is built to the kit specs.
Any help appreciated.
$$$... is offline
Old 03-03-2008, 10:19 PM
  #926
Pie_robot's Avatar
Trader Rating: 17 (100%+)
hi i had the same problem with my T2. Try puting more graphite grease in the cup, also u may have too much steering.
hope that helps
Pie_robot is offline
Old 03-04-2008, 03:56 AM
  #927
Customworksking's Avatar
Trader Rating: 74 (100%+)
I found it's with every car diff,1way and spool is real bad... no biggie it's fine
Customworksking is offline
Old 03-04-2008, 06:05 AM
  #928
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Check the set screw you're using on the axles!!! You must use the right size or else they'll bind. You gotta use the really short ones...and also make sure you add the grease
yyhayyim is offline
Old 03-04-2008, 08:01 AM
  #929
Anybody that has run a 17.5, can you tell me how it compares to a co-27 or 27T brushed motor.
wstcoastracer is offline
Old 03-04-2008, 08:38 AM
  #930
my last time 4 this so,don't kill me what is the int for the EU ? or tell how to do it I 4get it pullt dev by pully and ??
Contact Us Archive Advertising Cookie Policy Terms of Service
