Old 02-26-2008, 07:42 AM   #901
peded's Avatar
I think that inorder to achieve the correct fdr for the 17.5 you would have to run a 88 spur and a 44 pinion. I believe that is that correct
Xray T2 US '007, JR Z590 servo, KO PROPO EX-10 Helios, Novak GTB, Novak 13.5, EP4600?, Orion Advantage.
Sportworks Recoil - MMR Spec, GTX
Additional Feedback: http://rctech.net/forum/showthread.php?t=145047
peded is offline   Reply With Quote
Old 02-26-2008, 03:41 PM   #902
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Send a message via AIM to ALBERTO Send a message via Yahoo to ALBERTO
will an 88 spur reach a 44 pinion? The local hobby shop can get spurs as small as 80 tooth 64pitch. Will they fit/ reach????
ALBERTO is offline   Reply With Quote
Old 02-26-2008, 03:44 PM   #903
Customworksking's Avatar
Trader Rating: 73 (100%+)
the motor will only go so far back so, u better have pinions 42-50 and that may b over geared
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 02-26-2008, 04:08 PM   #904
adamge's Avatar
alberto, I think that that combination will reach. I used a 102 spur this weekend with the smallest pinion I could mesh, which was something like a 32.
Old 02-26-2008, 04:42 PM   #905
Trader Rating: 13 (100%+)
ive tried a 84t spur in mine and i cant get the motor to move close enough to touch. this past weekend i had a 96 spur with a 47 pinion in the car. it worked good i could have gone a couple of teeth higher but didnt have the pinions. i was rolling out at like 49.21mm the motor came off at 127 degrees
TEAM GENESIS R/C, Roche P12 2017, Roche F-1, PAINT BY MIKEY
onroad dude is offline   Reply With Quote
Old 02-26-2008, 04:44 PM   #906
ALBERTO's Avatar
guys this info is a big help!!! Im looking into a brushless system of the 008 and from the looks of it you all have worked out the kinks for me.. Thanks
Old 02-26-2008, 06:48 PM   #907
gonzo416's Avatar
Trader Rating: 39 (98%+)
again, how has everyone dealt with the issue of getting at the motor screw to tighten it? i have a 100 tooth spur and i have to get at through the standoffs and the hole in the spur at an angle but it is going to strip soon. has anyone come out with any fixes to this problem?
gonzo416 is offline   Reply With Quote
Old 02-26-2008, 06:53 PM   #908
Trader Rating: 16 (94%+)
Yo man, I know not what you speak of.
I've used a 96, 104, and 112 spur, PRS and Xray types with large holes in the spur, and I've not had too many issues getting to the screw. When I have, I've change the spur/pinion combo to allow better access. IF you intend to use only one specific size spur, than you will need to get used to tightening the outer screw, and then loosening the four screws in the top deck above the spur and lifting the spur up and out a little to reach the inside motor screw, then dropping the spur/layshaft back down and re-tightening the top deck.
kn7671 is offline   Reply With Quote
Old 02-26-2008, 07:46 PM   #909
gonzo416's Avatar
WOW!!! There has to be an easier way
Old 02-26-2008, 08:25 PM   #910
Welcome to Xray's super low bulkheads and the new, narrower gap between the motor bulkheads. It is much tighter in there, and w/o a long 2mm ball-hex screwdriver, the inner screw will be hard to reach. Like I said, I don't have this problem often, but I have a Hudy 2mm ball-hex driver.
Old 02-26-2008, 09:18 PM   #911
gonzo416's Avatar
thanks, i'll be getting a 2mm ball hex driver
Old 02-27-2008, 09:29 AM   #912
Johnny Wishbone's Avatar
Default Gears
The 102 that adamge ran had 2 of the opposing holes ovaled so that motor adjustment without any disassembly could be done. You can elongate the holes in the gear without fear of weakness because once the gear mesh is set and the motor is bolted down there is no down pressure on the teeth of the spur, just rotational torque, which shouldn't be effected with this mod. The spur was from a MSXMRE kit.
Johnny Wishbone is offline   Reply With Quote
Old 02-27-2008, 10:39 AM   #913
Trader Rating: 45 (100%+)
Anyone know what the lb ratings are for the 008 springs? I'm looking specifically for 2.4, 2.6 and 2.8 springs.
Apex is offline   Reply With Quote
Old 02-27-2008, 11:49 AM   #914
rtrsprint's Avatar
Send a message via Yahoo to rtrsprint
JUst to chime in im running a 17.5 with a 36 pinion and a 78 gear 48 pitch
www.xtremecrawl.com
rtrsprint is offline   Reply With Quote
Old 02-27-2008, 04:19 PM   #915
Nexus Racing's Avatar
R/C Tech Elite Subscriber
They don't list any specific lb ratings, but this chart should give you a good idea:
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
