Xray T2'008
Old 01-20-2008, 08:51 PM
  #766
I would eally like to get a 96 spur on there but I can see where it wil interfer with getting to the motor screws. The other 08 I run for mod I have been playing witha 116/21 gearing on a 3.5 Novak Lightwind and the Tc....but I think its just a tad off still.
Gitsum is offline
Old 01-20-2008, 08:54 PM
  #767
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
If your running 10.5 I really like 96 tooth lol.. some RW action going on, Actually any of the majors will fit if it has a 6 hole pattern. Kimbrough 96 is what I had in my oval box. So I sanded the spacer and vola, it works. Just flip the layshaft backwards.. That will do till my RW order comes in...
rx7ttlm is offline
Old 01-20-2008, 08:56 PM
  #768
Yea I dont know of anywhere else other then Nexxus that carries RW...I need to place a order here soon before Nats....what pinion would you settle with on the 96 with the Orion? This motor is new to me so Im still testing the waters here..
Gitsum is offline
Old 01-20-2008, 09:06 PM
  #769
rx7ttlm's Avatar
Hard to tell without running the track.. 38 -42?
rx7ttlm is offline
Old 01-20-2008, 09:13 PM
  #770
Thats about what I was thinking...the track flows pretty well. Due to my work schedule I get zero practice during the week so hitting the mark asap has its advantages lol....I'll probably start at 96/40 and go from there.
Gitsum is offline
Old 01-20-2008, 09:16 PM
  #771
rx7ttlm's Avatar
I started running brushless this season.. so I had every gearing estimate to short.. so now I just gear it to the moon till the motor stops liking it and its slugish.. not the way I would suggest.. But I started gearing 10.5 motors at 7:1 on asphalt.. and ended up with 4.9-5.3 lol..
rx7ttlm is offline
Old 01-20-2008, 09:22 PM
  #772
Wow! BL is a bit wierd seems the hotter the motor 10.5 vs3.5 the old gearing theory kinda goes away. Outdoors I tried a 116/18 and would thermal but inside it havent thermalled yet and have run upto a 116/21 so far with the same 3.5....go figure.
Gitsum is offline
Old 01-20-2008, 09:24 PM
  #773
rx7ttlm's Avatar
also consider ambient temp.. its probably nice and cool inside.. so you can take advantage of that.. and unless I missed something I dont think you will thermal the motor on the orion.. I know you can melt LRP motors.. But just keep an eye on the temps..
rx7ttlm is offline
Old 01-20-2008, 09:25 PM
  #774
rx7ttlm's Avatar
also keep in mind some of the 13.5/17.5 guys are going up to 4.0...
rx7ttlm is offline
Old 01-20-2008, 09:31 PM
  #775
Well after the 28th we are downsizing the track to the size Omaha runs in hopes of getting the gearing close before Nats....so I get to start all over again lol.....
Gitsum is offline
Old 01-20-2008, 09:32 PM
  #776
I think 17.5 will be a interesting class I may dab into....
Gitsum is offline
Old 01-20-2008, 10:05 PM
  #777
Customworksking's Avatar
Trader Rating: 74 (100%+)
Default 008
hello all I just got on with xray and will b ordering my cars Monday 1 foam and 1 rubber... what r must have parts running 10.5 foam and 13.5 rubber t...96 spur,caster blocks 4 6 ?,a-arms rear belts.? Kevin
Customworksking is offline
Old 01-20-2008, 10:13 PM
  #778
Personally my usual order is f/r arms, rear hubs, c hubs in 2,4,6s more 4s then 2, 6...steering blocks, a few extra screws and the metal inserts for the front c hubs. They tend to go flying when you break. I also toss in a 2 of each belt. That should about cover it. just really depends on how rough your track is on cars. Mine are all 2x4 boards so when you hit in mod things go everywhere...lol
Gitsum is offline
Old 01-20-2008, 10:21 PM
  #779
rx7ttlm's Avatar
you guys break things? lol, with the new 4 degree hubs I am not convinced they won't break. But I would buy some diff outdrives, m3, 2.5 grub screws in case one comes out, cross pins for the cvd's. I wouldn't bother with the 2 and 6 degree hubs. I would just buy those if you need them later on. I didn't even end up using 6 degree hubs with my foam car. spur gears(depending on class ex 10.5 I would get 92,96,100 from rw or similar), pinions for 10.5 in the 38-45 range. Swaybars, 1.4 front, 1.2 rear. That was one of the fiew changes I made to the stock setup that required parts.. maybe -.75 / +.75 hubs if you want setup options for quick changes.. belts, the usual front arms rear arms hubs f/r
rx7ttlm is offline
Old 01-20-2008, 10:25 PM
  #780
I only get the 2 &6 degree hubs to testing I rarely if ever use them...break things??? nah when u hit those 2x4's things explode not break....lol...especially at warp speeds.
Gitsum is offline
Contact Us Archive Advertising Cookie Policy Terms of Service
