Old 01-17-2008, 01:38 PM   #706
The Evicerator
R/C Tech Elite Subscriber
So how's everyone diggin' on their 008's?
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 01-17-2008, 01:48 PM   #707
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
faster out of the box than my 007, needed to tame it down a bit. softer bars all around. less rebound in the rear, more rebound in front. Also, I added a bit of throttle at 0% to idle up if you will. about .4mm more droop all around. Helped tame the car a bit. Doesn't transition as crisply as it did. But my lap times are better so who cares. But about 1/50th the work of getting my 007 car up to speed.. it pushed eternally.. then had a lack of rear grip off the corner when i got the mid corner balance to be just right.. 008. VERY NICE
now if I can just get my NT1 to where this car is on low bite I will be stoked. More testing this weekend at speedworld...
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 01-17-2008, 05:34 PM   #708
dag32's Avatar
Trader Rating: 109 (100%+)
I wish I could tell you how I like my 008 but I can not get the spur/ pinion correct I run Novak 13.5. This is my first Xray and this is a bit of a let down, but the rest of the kit is very nice and all parts went together perfectly. Can some of my fellow Xray drivers give a noviice some advice?
dag32 is offline   Reply With Quote
Old 01-17-2008, 05:58 PM   #709
The Evicerator
Dag,
Most people I know running 10.5s and 13.5s are running smaller spur gears than the standard kit gears. I believe they are running around 88 tooth 64 pitch gears and using the appropriate pinion for their motor/track.
Steve Weiss
Old 01-17-2008, 06:05 PM   #710
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Steve Weiss View Post
Dag,
Hi Steve,
About the Spur gears: the T2'008 still only can use Xray Spr gears, or the PRS or RW, or Kimbrough will work Ok also?
yyhayyim is offline   Reply With Quote
Old 01-17-2008, 06:20 PM   #711
Nexus Racing's Avatar
The RW and Kimbrough gears will fit if you sand the plastic pulley spacer a little thinner. I laid mine flat on a piece of sandpaper and moved it back and forth until it became the right thickness.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 01-17-2008, 06:22 PM   #712
The Evicerator
I have seen guys get RW gears on their car
Steve Weiss
Old 01-17-2008, 07:02 PM   #713
lbckevin's Avatar
Trader Rating: 91 (99%+)
I am using RW spur gear 88 tooth for the eu version. No problems.....
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 01-17-2008, 07:34 PM   #714
dag32's Avatar
I bought those same gears and I can not tighten the motor if I do that combo.
Old 01-17-2008, 07:47 PM   #715
HVFracingwilly's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to HVFracingwilly
96*52 works great you just have to take the top decks off to adjust the mesh
HVFracingwilly is offline   Reply With Quote
Old 01-17-2008, 08:06 PM   #716
Rainey's Avatar
Nexus made the comment earlier that the locals where he is at is using the RW 100s and they are drilling a hole in it to allow the driver to reach the motor screws. I have the RW gear... just havnt had the time to install it yet.
www.rcracingxtreme.com
racers running races for racers !
Rainey is offline   Reply With Quote
Old 01-17-2008, 08:17 PM   #717
Yep, just one strategically-placed small hole is all you need...since the spur gear is a good distance away from the motor mount, you'll even have room to get to the left motor screw at an angle if needed .
NEXUSRACING.com
Old 01-17-2008, 08:30 PM   #718
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Sorry if this is a repetitive question but what is the internal ratio?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-17-2008, 08:44 PM   #719
Rainey's Avatar
2.375
But i have a question. If you make the gear changes (to 34/20) like others have suggested, what is the "new" ratio?
Old 01-17-2008, 08:55 PM   #720
Super Moderator
Kraig's Avatar
Thanks Rainey. To answer your question I believe it is 34/20=1.7. Someone correct me if I am wrong.
