Xray T2'008
Old 01-14-2008, 05:40 AM
  #691
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Originally Posted by Mini Toink
Will Orion 3600 LiPo Batt fit in T2'008 or T2'007?
Thanks in advance!!
Toink
Orion 3600 LiPo today tested fit in T2'008 6 Cell chassis
RC MARKET is offline
Old 01-14-2008, 05:49 AM
  #692
RC MARKET's Avatar
Great thanks!
Want to see a 3600 on a T2'008 though
Toink
Old 01-14-2008, 08:47 AM
  #693
Mini Toink's Avatar
Trader Rating: 30 (97%+)
Great!! Thank you!!
Toink
Mini Toink is offline
Old 01-14-2008, 11:19 AM
  #694
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
which car/ tire setup. 3.5 chassis and foam or 2.5 and rubber tires...?
rx7ttlm is offline
Old 01-14-2008, 11:28 AM
  #695
RC MARKET's Avatar
EU
Old 01-14-2008, 01:27 PM
  #696
Nexus Racing's Avatar
Originally Posted by gonzo416
i fixed it. i just took the smallest grub screw from a 26 tooth pinion and ground it down and then at a 45 degree angle and now it is flush with the pinion.BELT SAVER....
by the way i ran it with a stock brushless and it is awesome, it has all the steering needed.
Yup, that's what I did as well. I put the set screw in my wrench and just moved it back and forth on a piece of sandpaper flat on a table until it became flush with the outside of the pinion.
Nexus Racing is offline
Old 01-14-2008, 01:52 PM
  #697
rx7ttlm's Avatar
Originally Posted by ghost rider
help guys
what do the diffs do up in the car,front & rear,and then i put them to down front & rear,:
which way is best for grip & handling,etc:
ok, I will try again. It depends on foam or rubber tires, and which chassis.
thanks,
Patrick
rx7ttlm is offline
Old 01-14-2008, 06:53 PM
  #698
Yet another method: I fitted the pinion backwards (that is with the screw oposite to the motor side) on a 17x1 motor. Conected it to 7.2 volts and ground the pinion with a file till 7.4mm. That will ground the pinion also, so i reinserted the hex driver ocasionaly to remove the aluminium from the screw.
Takes about 2 minutes
Itchy is offline
Old 01-14-2008, 08:15 PM
  #699
rx7ttlm's Avatar
for the truely talented, you can use xray part number 901302 on metric threaded pinions(ie ti racing) or you can thread the grub screw in backwards with locktite. grind down about 0.5 mm(my robinson pinions thats about all it took) and the heat from the grinding should free it up a bit and just take it back out by hand. if needed heat the thread locking compound with a lighter..
for the truely brave(i did this while i as mad) super glue your pinon grub screw to the allen tool and grind the non hex side... btw, dont degrease the screw or the tool lol..
-Patrick
rx7ttlm is offline
Old 01-15-2008, 01:47 AM
  #700
Hi Rc Market
When are you getting all the T2008 spare parts in stock?
zulu is offline
Old 01-15-2008, 09:28 AM
  #701
RC MARKET's Avatar
Originally Posted by zulu
Hi Rc Market
Today arrived !
New Shock Spring , upper deck , shock tower ...
Old 01-16-2008, 02:41 PM
  #702
The Evicerator
To the top!
Steve Weiss is offline
Old 01-17-2008, 12:11 PM
  #703
Customworksking's Avatar
Trader Rating: 74 (100%+)
tap
Customworksking is offline
Old 01-17-2008, 12:17 PM
  #704
nashrcracer's Avatar
wall
nashrcracer is offline
Old 01-17-2008, 12:22 PM
  #705
rx7ttlm's Avatar
no revelations today? man, someone needs to get to work..
rx7ttlm is offline
