Old 01-10-2008, 08:40 AM   #661
Mini Toink's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Mini Toink Send a message via Yahoo to Mini Toink Send a message via Skype™ to Mini Toink
Will Orion 3600 LiPo Batt fit in T2'008 or T2'007?
Thanks in advance!!
Toink
Xray T2'008 EU 6Cell
Hudy Pro Tools
AE 12R5
LRP : Orion : Sanwa (Airtronics) : Ko Propo : Spektrum
Mini Toink is offline   Reply With Quote
Old 01-10-2008, 12:11 PM   #662
Goingfast's Avatar
Trader Rating: 29 (100%+)
Thanks in advance!!
Toink
They should fit.....I know the between those two batteries are the same size.
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 01-10-2008, 03:15 PM   #663
lbckevin's Avatar
Trader Rating: 91 (99%+)
In the Eu rubber 6 cell chassis,
both Orion packs (3200 & 3600) fit just fine. You just need to remove the cell holders and slide the battery in . I taped the battery and still use the battery hold down for added weight.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is online now   Reply With Quote
Old 01-10-2008, 06:33 PM   #664
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Thanks in advance!!
Toink
ey mitch! i think the 3600 is the same size as the 4800.
anyway, here's what i did for my T2'007...
(pix)
shouldn't have a problem with the T2'008
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 01-10-2008, 08:15 PM   #665
Mini Toink's Avatar
Thanks for the reply guys!
Does anyone have a picture of 008 with a 3600?
Toink
Hudy Pro Tools
AE 12R5
Old 01-11-2008, 01:44 PM   #666
hi all... is there a way to get rid of steering chatter with a front spool? ive turn the epa down as much as it takes to stop the chatter... but it seems not enough steering?
i run on asphalt in the uk... on a tight track with in winter low to medium grip buh in summer very high grip.
could i run a fixed one-way maybe? or a normal one-way? without it swapping ends wiv going into the corners?
thanks jordan
P.S...THIS IS ON THE STANDARD T2'007
jordys jrxs is offline   Reply With Quote
Old 01-11-2008, 02:57 PM   #667
It is very important that the front drive shafts are regularly serviced. When the grease is gone it may still feel free on the bench, but while driving they will heat up and bind up which partially accounts for the chatter. If you are willing to service them every four runs or so you can use bearing oil instead of grease. This will work better but last shorter and also cause more wear.
Other than the axles, make sure the blades are regularly replaced. Also consider running less Ackerman if you can find a good setup with it. In my experience more Ackerman also causes more chatter. Finally someone posted a tip a while back to (not sure which website it was) to sand the edges of the wheel axles so the t-bone piece can just make a slightly bigger angle.
Hope any of the above works out for you.
tonyv is offline   Reply With Quote
Old 01-11-2008, 06:36 PM   #668
connyw's Avatar
Default ALU SHOCKS
Where can you by alu shocks to T2 ?
HB Ve8 / HPI Blitz ESE / Futaba 4PKs
T3 2011 / F1 F104Pro /Hpi Cup Racer
connyw is offline   Reply With Quote
Old 01-11-2008, 06:39 PM   #669
connyw's Avatar
thanks jordan
Lokk at the tips and trix at this site
http://nexusracing.net/newsdesk_info...6db93d961b4222
Old 01-12-2008, 05:23 AM   #670
mutley001's Avatar
Hi Guys
Ran my EU 6 cell 008 for the first time on Thursday whith brushless 10.5 and it was waaaaaay loose both off and on power when using the kit carpet rubber setup. Really fast but not able to turn in a consistent lap time on a big track with long straight but with some tight hairpin corners.
Any suggestions as to what to do first? Got a big race tomorrow and want to get it sorted!
Thanks in advance
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 01-12-2008, 06:05 AM   #671
Jonny Aird's Avatar
Originally Posted by mutley001 View Post
Hi Guys
Thanks in advance
Hi Mutley,
A few of the UK team drivers have been really happy with their cars on carpet. The 2 big changes that we have made from the kit set up is going from 1.6/1.4mm roll bars to 1.4/1.2mm roll bars, just to soften the car up and give it a bit of roll. With the kit set up it stays very flat.
We also always run 1mm shims on the front and rear hubs and raise the camber link up 1 hole all round. This makes the car much easier to drive.
They are the 2 things I'd definitely suggest trying first.
Hope this helps
Jonny
XRAY | Hudy | Spektrum | Moorespeed | MB Models | Serpent |APE
Jonny Aird is offline   Reply With Quote
Old 01-12-2008, 06:54 AM   #672
mutley001's Avatar
Thanks Jonny, might have to wait to give the roll bars a try as I haven't got any others yet but will certainly try the roll centre chnges.
Paul
ARC R11 2017
ARC R10 2013
Team EAM
Old 01-12-2008, 07:39 AM   #673
Hi Mutley
It seems a few of us are having the same problem so it will bee interesting to see if the changes work.
When will you be running next ?
Steve B is offline   Reply With Quote
Old 01-12-2008, 10:43 AM   #674
mutley001's Avatar
Running at Carpet Wars tomorrow and then my next club meet is Thursday evening. Looking forward to tomorrow. Be the first real chance to use the Xray in anger! Will let you know where I get to with the changes.
ARC R11 2017
ARC R10 2013
Team EAM
Old 01-12-2008, 04:31 PM   #675
Will also be running my 008 at Carpet Wars tomorrow.
Will try some changes but need to get different roll bars and
waiting on XRay to bring out the other springs for the car.
Livingston is offline   Reply With Quote
