Old 01-08-2008, 10:14 PM   #646
lbckevin's Avatar
Trader Rating: 91 (99%+)
I did not have to modify the spur at all. I had to tap the pin in with a set of pliers, (stock one just dropped in) but took 10 seconds.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is online now   Reply With Quote
Old 01-08-2008, 10:18 PM   #647
Moonfrostee's Avatar
Okay, now i understand why there are such large gearing differences. I am running the us edition with 20t pulley's and 64p gears.
I normally run 112spur and 37pinion for a mixed layout carpet track.
Moonfrostee is offline   Reply With Quote
Old 01-09-2008, 04:10 AM   #648
Default why belts
Guys,
i dont run an '08 (as yet) and im strugglung to make sense of what the drama is with the belts and pullys. Why Schumacer and Yokomo etc. the xray belts and pullys not good enough?
To save my embarrasment can someone pls PM me and let me know the story.
Cheers
Bluey_74 is offline   Reply With Quote
Old 01-09-2008, 09:46 AM   #649
rmargiotta's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to rmargiotta
It's nothing to be embarrassed about!
To get the motor and battery (the most massive parts on the car) as close to the center line/eachother and to get the put gear and pulleys and the angular momentum created by them on the center line, XRAY split the pulleys and put the spur in between them which created a problem with pinion gears (mostly the grub screw in them) to be very close to the belt. And something to do with how the 16T pulley and 38T diff make the rubber tire car better, they went to that, which makes it very hard to get the correct gearing to 13.5/10.5 brushless, so some guys are going back to the old pulleys or mixing stuff to better accommodate gearing.
As I have told several customers over the phone, I would recommend running the following gearing in their '08's for 13.5/10.5:
Foam: 96T/41T 64 Pitch (convert to 48P by multiplying teeth by .75)
Rubber: 78T/34T 48 Pitch (convert to 64P by multiplying teeth by 1.3333)
rmargiotta is offline   Reply With Quote
Old 01-09-2008, 09:59 AM   #650
Could we talk XRAY into a 22T pulley? The main challenge with brushless motors is getting the FDR needed with such a large spur..
If the pulley went up to 22T, it would increase the clearance for the belt to pinion set screw, and it would change the ratio enough to use the stock spur/pinion combo..
Call it a "brushless upgrade" and simply change 1 part (20T pulley to a 22T pulley), which would resolve a lot of this...
Darint is offline   Reply With Quote
Old 01-09-2008, 10:17 AM   #651
rmargiotta's Avatar
Mario has posted this in the XRAY forum regarding the Pinion/Spur deal with the '008.
http://forum.teamxray.com/viewtopic.php?p=63241#63241
Old 01-09-2008, 10:19 AM   #652
Johnny Wishbone's Avatar
Johnny Wishbone is offline   Reply With Quote
Old 01-09-2008, 10:59 AM   #653
rmargiotta's Avatar
I would PM or email HUDY/Mario directly about this inquiry.
Old 01-09-2008, 11:24 AM   #654
I reread the article, but it looked targeted to the EU spec crowd and changing pulley's and diffs to the US spec for Brushless due to the rubber spec car already having a higher internal gear ratio than the US spec..
I have the US foam spec with Mario's suggested diff and pulley combination, and run into the challenge with the stock spur (116t) not able to fit a large enough pinion for the roll-out the brushless motors are capable of.
I solved the issue by purchasing a 100T spur, but the suggestion of an option of a larger center pulley, resulting in a lower internal gear ratio would offer several benefits to the brushless crowd (EU and US).
1. Increased spacing between the pinion and the belt eliminating belt wear issues
2. Allows the brushless users an option us to use a standard size Spur, which allows easy access to the motor screws, and the advantage of offset spurs made by XRAY (currently the smallest is 112 I believe?), which helps with the additional space for the battery/pinion concern.
3. The drivers are able to use current pinion sizes instead of purchasing differing sizes (from brushed to brushless).
4. An ability for a brushless user to purchase a kit and race, without purchasing new spurs/pinions and worrying about belt wear.
5. Easily executable (changing of a pulley mold), which provides more options.
Sorry for the long winded post, just seemed like a light bulb went off for an easy solution.
Old 01-09-2008, 11:30 AM   #655
RC MARKET's Avatar
Trader Rating: 12 (100%+)
My EU-5cell very hard gear ,
the spur gear can't use smaller spur gear 110-112T... , for balance torque !
do you have more lower center shaft holder ?
for use small size spur gear & don't touch pinion gear !!
Old 01-09-2008, 11:34 AM   #656
rmargiotta's Avatar
Feel free to be proactive with any inquiries like this.
There is a whole thread dedicated to requests like this on the XRAY forum.
Below are a few links to contact XRAY/Mario about this.
Mario's Profile on XRAY's Forum
[email protected]
or heck, their phone number!
+421-32-7440 180
I will also email Mario about this.
Old 01-09-2008, 11:56 AM   #657
Nexus Racing's Avatar
R/C Tech Elite Subscriber
The guys here have been running 100-102t spurs and 48-50t pinions with 13.5 brushless on the EU edition. The only problem really created by this is motor mount screw access...and that was solved by drilling a small hole in the spur towards the outside of the gear. Once it is done, though, it is not really a big deal.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 01-09-2008, 12:12 PM   #658
Joep's Avatar
Please post these suggestions on the Xray forum.
I'm sure Xray will provide a solution knowing their past and current customer support
Joep is offline   Reply With Quote
Old 01-09-2008, 05:22 PM   #659
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Default Gear Chart
So, Ive been unable took keep up with this thread lately and Ive missed some good info Im sure. Anyway my question is did anyone else get the wrong Gearing chart with thier kit? As in for a different car all together.
mrrcguy is offline   Reply With Quote
Old 01-10-2008, 07:53 AM   #660
Yes. Check X-ray web site for correct downloadable info card.
