Old 12-22-2007, 12:28 PM   #541
dodo's Avatar
Send a message via Yahoo to dodo
Originally Posted by RC MARKET View Post
yes update pack was arrived !
what are these updates about? i see bearing holder, swaybar mount, and something about the universal shaft.
do all first batch kits need to get these updates? cos i don't see anything wrong (yet) in regards to the parts pictured.
dodo is offline   Reply With Quote
Old 12-22-2007, 02:25 PM   #542
RC MARKET's Avatar
Trader Rating: 12 (100%+)
yes this 3 packs !
with some problem !
Old 12-22-2007, 10:48 PM   #543
c1 racin's Avatar
Send a message via ICQ to c1 racin Send a message via AIM to c1 racin Send a message via Yahoo to c1 racin
On the '008 EU is it possible to use the 20T (305577) center layshaft pulley and rear belt (305443) with Composite solid axle 38T (305188) and ball diff set 38T (305003) to get a drive ratio of 1.9 Anyone tried it
NeXusRacing.com
MurnanModified.com
MobileRCRacing.com
c1 racin is offline   Reply With Quote
Old 12-22-2007, 10:50 PM   #544
ChrisP's Avatar
This question was also posed on the Team Xray forum, and no, it cannot be done with the parts that are currently available. New belts would be required.
ChrisP is offline   Reply With Quote
Old 12-22-2007, 11:53 PM   #545
G Mills's Avatar
Just got mine together. I can't wait to get it on the track.
G Mills is offline   Reply With Quote
Old 12-23-2007, 01:55 AM   #546
As Chris P said new Belts are needed.
I have how ever done this mod but you need the front belt off the Schumacher Mi3, Rear belt off a Yokomo BD and a 20T pulley off something like an FK05 (Part number 305575) to go with the Mi3 belt which is 3.5 wide instead of 3mm and take off the raised lip on this pulley where the E clip goes. The 008 layshaft pulleys are 0.5mm narrower.
Hopefully Xray will bring out some longer belts but untill then this works well and the pinion now clears the front belt no problems plus I can use a better spur / pinion comcination for my 10.5 BL.
Steve B is offline   Reply With Quote
Old 12-23-2007, 04:33 AM   #547
About pinion problem... where can I find 48p pinions 3,5mm wide?
I know xray announced the new pinions but I can't find them anywhere to buy...
saciccio is offline   Reply With Quote
Old 12-23-2007, 07:04 AM   #548
I drove the car with rubber tires yesterday on a high grip track.. it was super easy and super fast! Really nice to drive and 1 full day off racing and no wear or what so ever, i race brushless 3.5t with 5cells. Verry nice! Verry impressed by this kit!
Lrpcyclone is offline   Reply With Quote
Old 12-23-2007, 07:58 AM   #549
dodo's Avatar
yes this 3 packs !
with some problem !
tested the car today. awesome. i suppose the swaybar mount is for the rear swaybar, today i noticed that the pulley is rubbing against the swaybar (EU setup).
those pinion vs battery bars issue is pain in the a$$ hahahahaha but solved nonetheless. interim remedy. the best solution will be to use thinner pinion gear.
Old 12-23-2007, 08:20 AM   #550
Piyo Piyo's Avatar
Tested mine today on a semi-wet track.
Car is more stable, with little tendency to lose traction (cause of the track)
While responsiveness and front traction is quite same with 007.
The set-up is a little bit different between instruction manual and basic setting sheet, so I follow the setting sheet one. With change only to front downstop 4.4mm and front one 6mm.
Good car, can't wait to test it on dry high-grip track. .
One thing still annoyed me. The front belt still rubbed at left side of it.
This thing hapened also on T2 and T2 007.
Anyone experienced the same problem? Any answer to it?
VIOLA ARIELLE & FLOREN ISABELLE
Piyo Piyo is offline   Reply With Quote
Old 12-23-2007, 08:28 AM   #551
ChrisP's Avatar
These issues are being dealt with by the parts package currently being distributed to distributors around the world.
Old 12-23-2007, 10:11 AM   #552
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
It sure would be nice to see some good pictures of the 08 EU with a hard case lipo installed!
mrrcguy is offline   Reply With Quote
Old 12-23-2007, 02:28 PM   #553
I can post picture (s) of a Orion 3200 fitted if thats any help.
Old 12-23-2007, 03:22 PM   #554
Goingfast's Avatar
Trader Rating: 29 (100%+)
Default Team Tamale
Who sell the Tamale products online?
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 12-24-2007, 08:55 AM   #555
rraden's Avatar
Trader Rating: 235 (100%+)
Team Tamale
http://www.teamtamale.com/
rraden is offline   Reply With Quote
