Old 02-07-2011, 09:16 PM   #1846
gonzo416's Avatar
Trader Rating: 39 (98%+)
Originally Posted by Rockin Rich View Post
XRAY 38T Pulley Rubber-Spec Conversion Set (T2'009)
[XRA300944]
* 305058: T2 008 Diff Pulley 38T with Labyrinth Dust Covers
* 305188: T2 008 Composite Solid Axle 38T - Set
* 305432: High-Performance Kevlar Drive Belt Front 3x513mm
* 305446: High-Performance Kevlar Drive Belt Rear 3x189mm
So I'm assuming that I can convert it to 1.9 because of your post. I thought we can only go to 1.7 but I have all the parts, so i'll get on it tomorrow. Thanks Rockin Rich
gonzo416 is offline   Reply With Quote
Old 03-25-2011, 08:07 PM   #1847
Default t2 008 rubber is it the same as t2 008 foam?
Q as title ...can the T2 008 chassis be interchangeable with rubber to foam ? Do all the holes line up if so what are the difference with them? Thanks
urban is offline   Reply With Quote
Old 03-25-2011, 08:17 PM   #1848
I)arkness's Avatar
almost the same except the foam is thicker which makes it more stiff, i think there are a few extra holes, for the top deck braces they had on foam chassis.
other then that i think all the other holes will line up.
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 03-26-2011, 11:17 AM   #1849
gonzo416's Avatar
There a few guys I know running a 08 & 09 foam car with rubber tires on them. There lap times are pretty close to us guys running the rubber tire version.
Old 03-26-2011, 07:16 PM   #1850
gonzo so would i setup the foam chassis with rubber spec sheet
Old 03-26-2011, 10:02 PM   #1851
Johnn27's Avatar
Trader Rating: 72 (100%+)
Default Should I replace my chassis
I have a T2 2008 and love how it drives and handles. The chassis is showing wear on the bottom along the outer edges and the front and rear. I want to replace the chassis but worry it will change the handling since this chassis is broken in am I Crazy? Should I just leave it alone?
Johnn27 is offline   Reply With Quote
Old 03-27-2011, 04:47 PM   #1852
rcko's Avatar
Trader Rating: 15 (100%+)
I plan on upgrading to the exotek chassis. more affordable than xray oem... narrower, ei less scrubbing
I have been happy with my 08 so far. It keeps up relatively well against the newer cars except for slow speed lollypop type turns. I think the geometry changes of the t10/11 and others like tamiya show an advantage in these areas. Otherwise, open flowing tracks, it holds its own really well. it is a really good value racing chassis.
rcko is offline   Reply With Quote
Old 03-27-2011, 04:53 PM   #1853
gonzo416's Avatar
I'll see if I can get his setup for yo. I"m ging to lok into te exotech chasis myself. I have a T3 & I get the same lap times with my T2 08.
Old 04-05-2011, 05:13 PM   #1854
gonzo416's Avatar
I haven't been able to get his set up because he hasn't been at the track.
Old 04-05-2011, 05:14 PM   #1855
gonzo416's Avatar
Has anyone tried the spec r gear diffs in the 08 yet?
Old 04-05-2011, 07:07 PM   #1856
rcko's Avatar
spec r will go in this wkend. will post how it went if I can find this thread again.
I did replace the factory lower chassis with the exotek unit. Ran it Sunday and it actually worked really good. The install was simple. Everything bolted up with no issues. quality seems good.
It does seem to be thinner than the oem chassis so make sure to take time torquing the bulkheads evenly and ckng on the setup board to make sure the chassis stays flat.
car really doesnt seem to be lacking against the T3 in open tracks. Yet to run it against them in tight tracks again with the current changes.
Old 04-05-2011, 10:34 PM   #1857
Johnn27's Avatar
Questions?? exotek chassis
Who sells the exotek chassis for the t2 ' 2008 . north american seller?
Are you guys using the chassis with the steel battery holders or the no weight limit graphite chassis???
Old 04-05-2011, 10:54 PM   #1858
Brokin Racing's Avatar
R/C Tech Elite Subscriber
Trader Rating: 68 (100%+)
Seriously, whilst I've got late model cars, I still use the 08, mine can easily out turn late models in the tight turns at the track I go to. If you can, do the following to it...
1.5mm Spec-R top deck
TRF Shocks... Space the front shocks foward
Ceramics (use Shumacher ones, they're cheaper & better)
Set it up to kit spec..& away you go
Xray - LRP - PF - Futaba -
"Retired from Racing"
Brokin Racing is offline   Reply With Quote
Old 04-05-2011, 10:56 PM   #1859
Spec-R have them & you can get the 34t housing so you don't have to change gearing
Old 04-05-2011, 10:57 PM   #1860
Forget the appearence, leave that to the wankers, just race it & enjoy the fact you're beating them with an older model
