Old 09-30-2009, 07:48 PM   #1786
adamge's Avatar
lowcel, run the smallest spur you can. If you go Xray brand, that means their 104t. There's an aftermarket brand that offers smaller, with about a 96t being ideal for those motors.
-Nietzsche
Old 09-30-2009, 08:20 PM   #1787
lowcel's Avatar
R/C Tech Elite Subscriber
Trader Rating: 80 (100%+)
Thanks. Will this one work? I'm not sure what it means by offset.
Will a 104/42 fit on it?
Team Whopperjawed Racing
This hobby is going to $5 me to death.
lowcel is offline   Reply With Quote
Old 09-30-2009, 08:27 PM   #1788
Regional Moderator
CarbonJoe's Avatar
Try one of these: http://www.nexusracing.com/index.php?cPath=145_321_322
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 09-30-2009, 08:32 PM   #1789
Tire Chunker's Avatar
Trader Rating: 16 (100%+)
Originally Posted by lowcel View Post
Could someone help me out with some recomendations for gearing? I am planning on running stock with a 17.5 brushless and vta with a 21.5 brushless motor. I will be running on carpet. In vintage I need a final drive ratio between 4.2 and 4.6.
I need to buy some spur gears, just not sure where I should start. The only ones that came with the car are a 116 and a 118.
88t for 17.5 in my Fk'05 and I run a 100t for 13.5 in the 008.
Tire Chunker is offline   Reply With Quote
Old 09-30-2009, 11:25 PM   #1790
adamge's Avatar
Yeah, that's the one. The offset isn't important. The requirements of a spur to work on a T2 are the motor screw access holes (the big ones near the outside) and the Y-pattern layshaft screw holes.
-Nietzsche
Old 10-01-2009, 02:58 AM   #1791
jebs's Avatar
Send a message via Yahoo to jebs
Hi! I am planning to buy a used box stock T2008 and will be racing 3800 Orion LiPo 13.5 rubber on asphalt
With the EU 6cell version, I have a few questions before I buy the kit
1. Are there modifications/optional parts needed to the car to make it competitive? (ie i have read about the pulley upgrade, is it needed?)
2. What spares will I usually need to carry on a race day?
3. Will standard, aftermarket spurs and pinions, not the thin xray ones, fit on the car? (i still have my standard 64P pinions and spurs)
4. Is the kit shocks good, compared to aluminum shocks of other cars?
I am worried about these because I know that xray parts are expensive compared to parts for my previous car and I would not like to be over my budget with spares and modifications by buying this car
jebs is offline   Reply With Quote
Old 10-01-2009, 05:45 AM   #1792
lowcel's Avatar
Originally Posted by CarbonJoe View Post
Thanks for the link, going to order a few things from them.
Here is what I will have after I order, please make any recomendations if you see something missing that I should have.
pinions - 22-32, 45
spurs - 72, 80, 90, 116, 118
Old 10-01-2009, 07:27 AM   #1793
Regional Moderator
CarbonJoe's Avatar
pinions - 22-32, 45
A 96 tooth spur will fit the bill for both classes. I'd get more than one in case you strip the teeth off the spur (if the motor comes loose, it will shear the teeth off the spur in no time.) For pinions, VTA would require probably 34 - 38, and 17.5 up to about 43. No need to go below 34 or above 43 in either case.
Old 10-01-2009, 08:57 AM   #1794
lowcel's Avatar
Thanks, just placed my order.
1 x 64P XRAY-Series Spur Gear - 80 Tooth (fits T2'007 & T2'008)
1 x 64P XRAY-Series Spur Gear - 96 Tooth (fits T2'007 & T2'008)
1 x 38T 64p PRS Pro-Lite Pinion Gear
1 x 37T 64p PRS Pro-Lite Pinion Gear
1 x 36T 64p PRS Pro-Lite Pinion Gear
1 x 32T 64p PRS Pro-Lite Pinion Gear
1 x 31T 64p PRS Pro-Lite Pinion Gear
Old 10-01-2009, 08:51 PM   #1795
magee's Avatar
what spur and pinion would i need for the t2 07 21.5 brushless VTA racing on asphalt rubber tire the rules say no lower then 4.2 i need to find a sweet spot far as pinions and spurs and roll out iam lost
magee is offline   Reply With Quote
Old 10-01-2009, 09:06 PM   #1796
Regional Moderator
CarbonJoe's Avatar
96 spur, 35 - 38 tooth pinions. With a 96 tooth spur, a 35 tooth gives you 4.6, 38 gives you 4.29 FDR.
Old 10-19-2009, 08:31 AM   #1797
gonzo416's Avatar
Trader Rating: 39 (98%+)
anyone know if the smc 5200 50c fits using the xray lipo balancing weights?
gonzo416 is offline   Reply With Quote
Old 10-19-2009, 02:30 PM   #1798
sukh's Avatar
yes it fits
Can West RC
Xray canada
Fastcats
Bawdy Shop
Express Motorsports
sukh is offline   Reply With Quote
Old 10-19-2009, 06:31 PM   #1799
lowcel's Avatar
Could someone tell me what size turnbuckle wrench I need for the turnbuckles on the T2'008?
Old 10-19-2009, 06:33 PM   #1800
Regional Moderator
CarbonJoe's Avatar
3 mm.
http://www.amainhobbies.com/product_...kle-Wrench-3mm
