Xray T2'008
Old 07-07-2009, 09:54 PM
  #1741
hound_dogs_01's Avatar
Trader Rating: 16 (100%+)
Ok So I just recieved my 008EU car and im wondering a few things...
1. How do I know if the belt is tensioned right?
2. How do I know my rear diff is tight/loose enough and how do I adjust it? i know stick a hex driver in the hole but which way tighens/loosens the diff up?
Thanks a ton!!!
I really love this car it drives amazing...
Alex
hound_dogs_01 is offline
Old 07-07-2009, 10:47 PM
  #1742
Verndog's Avatar
Originally Posted by Nexus Racing View Post
Yup, the diffs and spool will fit...not perfect, but definitely acceptable. In fact, most guys here with 007's have the 305184 Composite 008 Spool installed!
Sweet, where there's a will, there's a way. Thanks Franco and Arun...be expecting an order shortly.
Verndog is offline
Old 08-09-2009, 02:16 AM
  #1743
tazz888's Avatar
Trader Rating: 24 (100%+)
I just received a NIB 008 US spec kit as parts of a trade with a buddy of mine.
What is needed to convert it to a EU spec kit?
tazz888 is offline
Old 08-09-2009, 09:26 AM
  #1744
Trader Rating: 33 (100%+)
Chassis, upper deck, hard arms front and rear instead of the extra hard, medium c-hubs and rear uprights, 52mm driveshafts, and a spool for the front.
But you could get away with just the chassis and upper deck, and replace the other stuff as needed.
chensleyrc1 is offline
Old 08-09-2009, 03:05 PM
  #1745
mickrcarver's Avatar
Trader Rating: 98 (98%+)
youll need a rear belt too ,the eu chassis moves the bulkheads ,i think the part number is 5444 for the eu 008/009
mickrcarver is offline
Old 08-09-2009, 03:52 PM
  #1746
I knew I was forgetting something!
Old 08-09-2009, 05:23 PM
  #1747
rovpilot26's Avatar
Default Pinion and or motor help...
We ran today after finally drying the track out after a good rain.
My 2'008 ran fine however was seriously lacking in the straights.
The guys I am running against are running 4.5 motors against my 7.5 Novak GTB.
Here is the setup and temps.
114 spur (I think), 27 pinion, 2S 4900 lipo, Novak GTB 7.5.
The car has good power in the technical portions of the track but needs a bit more to be competitive... Should I just go to a 4.5 motor or is there a pinion combo that will keep me in the pack?
Motor 150* ESC 120-130* Pack 110*
rovpilot26 is offline
Old 08-10-2009, 09:09 PM
  #1748
rovpilot26's Avatar
Default Is it necessary...
Is it necessary to convert from US to EU for running on asphalt... Or are there better ways to make the car perform on asphalt...
Just trying to keep up with the joneses....
Old 08-10-2009, 09:58 PM
  #1749
if your running a foam chassis on asphalt with rubber tires your not getting ANY flex what so ever so your arent getting any kind of traction whats so ever.... so yes to be fast on asphalt w/ rubber tires use the EU kit
Alex
Old 08-10-2009, 10:30 PM
  #1750
#88driver's Avatar
If you were to run the us on asphalt, use the absolute softest possible flex setting, run soft springs all the way around such as 2.4's or 2.6's, lean your shocks in pretty far, and use some pretty soft roll bars like 1.2's, and go from there. It would be smart to convert, but it is possible to make it work
#88driver is offline
Old 08-10-2009, 10:32 PM
  #1751
rovpilot26's Avatar
Default Outer posts...
I removed them and got some flex out of the car. It is handling better in the turns so far. What all do I need to get more flex out of it?
Also what spur should I go to with a 4.5 motor and be able to keep the 64p pinions I have?
Help a fella out...
What is the best way to get this thing to run on asphalt?
Old 08-10-2009, 10:33 PM
  #1752
#88driver's Avatar
Alex
And your still getting some flex, just not as much. And you cant be fast on asphalt with rubber tires on the US kit
Old 08-10-2009, 10:34 PM
  #1753
#88driver's Avatar
Help a fella out...
Use the 118t spur.
Old 08-10-2009, 10:38 PM
  #1754
I use 106 spurs but i also only run vintage at the moment...
Alex
Old 08-11-2009, 09:56 AM
  #1755
Can someone list the changes from 008 to 009?
billythekid is offline
Contact Us Archive Advertising Cookie Policy Terms of Service
