Xray T2'008
Old 12-28-2008, 09:02 PM
  #1696
Trader Rating: 17 (100%+)
I ran my new 008 for the first time today (17.5 foam carpet)
I was having odd handling problems and it turns out that the rear shock were maxing out before the droop set screw would hit the chassis. Not by too much but enough to effect the setup.
My friend has the 007 and it has longer rear shock body. My 008 manual leads me to believe all four shocks are the same size now, even the shock shafts. I unscrewed the ball cups on the shock shaft a little but I rather not compromise the shock ends when I think there should be another solution.
Any suggestions????
seabass2500 is offline
Old 12-28-2008, 11:27 PM
  #1697
adamge's Avatar
Are you running adjustable pinions?
adamge is offline
Old 12-28-2008, 11:45 PM
  #1698
pcar951's Avatar
Trader Rating: 20 (100%+)
Any suggestions????
I emailed Paul L. about this exact issue last year. He orients his shocks so that the locating dog on the adjustable piston drops into the recess in the shock body when fully extended. He also suggested to unthread the shaft ends a bit to get the travel you need. I made the changes and it gave me enough to run my foams to 56mm. Hope this helps.
pcar951 is offline
Old 12-30-2008, 04:29 PM
  #1699
thanks for the info
i'll give it a try
Old 12-30-2008, 07:44 PM
  #1700
RC Huligan's Avatar
Originally Posted by ultegrasti View Post
any1 know if the fella on ebay thats sellin 008s 400 obo legit, with all these fake/copy stuff goin on?
I don't know about the eBay guy specifically, but RC America reduced the dealer cost on the T2'008 so they can empty their inventory. If he is just reselling those kits from RC America he's not making anything. Maybe he's a dealer just unloading stock.
Update: I completely forgot to mention that the new dealer price is $400.
RC Huligan is offline
Old 12-30-2008, 11:33 PM
  #1701
Akhor's Avatar
Originally Posted by Akhor View Post
I've got what I think is a weird problem.
It seems as though the inside of my pinion (Part on the pinion where the lock nut is tightened down rubs against my drive belt.
Obviously this causes excessive wear on the belt. So I can only get a few races out of them. I've tried re-positioning the motor, but no luck. In order for the right mesh, it has to be where it is.
I'm running a brushed motor with the 2.375 (20 inside pully).
Any ideas?
FYI, apparently this is because of the 2.375 gear ratio. Supposidly if I change to the 1.7 this will no longer be an issue.
Akhor is offline
Old 01-03-2009, 07:54 PM
  #1702
RielTime Racing's Avatar
What are your thoughts or opionions on the topic of gearbox ratio's http://www.rctech.net/forum/electric...ox-ratios.html
RielTime Racing is offline
Old 01-08-2009, 02:00 PM
  #1703
Need some quick info.
I have a 008 EU rubber spec 6 cell on its way to me. I will need to be around a 4.2-4.7 FDR. My understanding is this car will have the 2.3XXX ratio???
Can I get to the FDR I want with this, or am I going to need to change to 1.7?
Do I need to change belts if I change ratio, or do they still fit?
I will get time to read through this whole thread in the next few days and probably find the info, but I would like to get the parts ordered ASAP if I'm going to need them.
Any help would be appreciated.
Stetler17 is offline
Old 01-08-2009, 02:16 PM
  #1704
The Evicerator
It will be much easier for you to reach that FDR with the 1.7 ratio.
To change the ratio you need to change the layshaft pullies and the diff/spool pullies... the belts are the same.
Steve Weiss is offline
Old 01-08-2009, 04:13 PM
  #1705
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Rear belt doesn't fit from 38T to 34T. Front belt is the same.
ToysRUsKid is offline
Old 01-08-2009, 08:25 PM
  #1706
RobS's Avatar
For the belts to fit you have to change both the layshaft pully and the diff pully. You can only run the combination of 16/38 (2.375) or 20/34 (1.7), not a 20/38 (1.9)...
RobS is offline
Old 02-05-2009, 06:38 PM
  #1707
corney_01's Avatar
hey guys i just got a 008 5 cell and want to run lipos just want to know wat is needed to do so
cheers steve
corney_01 is offline
Old 02-05-2009, 06:41 PM
  #1708
ChrisP's Avatar
It will depend largely on which LiPo pack you want to run in the car?
Some will fit without modifications, others will require shimming, etc...
ChrisP is offline
Old 02-05-2009, 06:45 PM
  #1709
Green Machine's Avatar
Trader Rating: 14 (100%+)
im looking at the intellect 5000 lipos
Green Machine is offline
Old 02-05-2009, 06:51 PM
  #1710
corney_01's Avatar
sorry wrong profile but yer intellect 5000
