Old 12-16-2008, 08:54 AM   #1681
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
Originally Posted by Akhor View Post
What if you did not change this, and instead only change to the 20t.
Could you not just use the higher internal gear ratio of 1.9 (38 Spool / 20t) for your calculations?
i tried, belts don't fit.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 12-16-2008, 08:59 AM   #1682
ToysRUsKid's Avatar
Originally Posted by BBSpence View Post
305054 is the 34t gear/cover for the diff, multi diff and delrin spool
305184 is the 34t solid composite spool
can't find that second part at any stores "305184"
Old 12-16-2008, 09:07 AM   #1683
BBSpence's Avatar
Trader Rating: 45 (100%+)
A quick google search found several online stores that stock it. If your local track/hobby store can't get it, ampdraw.com has it in stock.
BBSpence is offline   Reply With Quote
Old 12-16-2008, 09:08 AM   #1684
Akhor's Avatar
Good to know.
When you do find the front spool, please post where you got it.. I'll do the same.
Akhor is offline   Reply With Quote
Old 12-16-2008, 09:28 PM   #1685
Nehpets's Avatar
Trader Rating: 23 (100%+)
I'm wondering if someone could give me a 48p gearing starting point for an LRP 3.5 motor running rubber tyres on a tight asphalt track.
I've looked at a few Team Drivers setups and they seem to run 116 - 118 spur with 20 - 23 pinion for a 3.5 BL. Is that 48p or 64p? I'd definatly need 48p for our track.
Maitland Off/On Road Radio Car Club - http://www.morcc.com/
Nehpets is offline   Reply With Quote
Old 12-16-2008, 09:34 PM   #1686
#88driver's Avatar
That would be for a 64p. For a 3.5 BL 48p you would want an 84t spur with about 15-16t pinion to get about the same PDR.
Colton Jaynes
*RC America*Hudy*Xray*Jaco*KO Propo*SMC*EA Motorsports*
rchobbiesstore.com
#88driver is offline   Reply With Quote
Old 12-16-2008, 09:45 PM   #1687
Nehpets's Avatar
Awesome, Thanks buddy.
Old 12-22-2008, 12:22 PM   #1688
ToysRUsKid's Avatar
Originally Posted by EAMotorsports View Post
The SMC 4000 pack will fit. The 5000 will require the top deck to be raised 1mm or mounted like the pic below. The trinity IP3800 will also fit without raising the top deck. Those are the only two I know of besides 3200 packs.
EA
Is the trinity IP3800 flat on the bottom or does it have the humps?
Old 12-22-2008, 01:02 PM   #1689
ngo8's Avatar
Send a message via ICQ to ngo8
it has humps on the bottom .
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 12-23-2008, 08:30 AM   #1690
ToysRUsKid's Avatar
Default Question about FDR on a T2'008 Rubber vs Foam
How can I match a FDR of 4.5 on the Foam car to the Rubber car knowing that only certain combinations of spur/pinions will work on the car?
I'm running 17.5 brushless and trying to get to a 4.5 that was at when i ran the foam car as a rubber car. now that i have the new drivetrain (2.375 ratio), how can i get back there?
The gear chart from xray have the two cars at completely far apart FDR's for the same gears. it's very confusing.
Old 12-28-2008, 08:46 AM   #1691
Akhor's Avatar
I've got what I think is a weird problem.
It seems as though the inside of my pinion (Part on the pinion where the lock nut is tightened down rubs against my drive belt.
Obviously this causes excessive wear on the belt. So I can only get a few races out of them. I've tried re-positioning the motor, but no luck. In order for the right mesh, it has to be where it is.
I'm running a brushed motor with the 2.375 (20 inside pully).
Any ideas?
Old 12-28-2008, 09:27 AM   #1692
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
The quick answer is you can't. Most, if not all of the people who run 17.5 brushless use the 1.7 ratio pulleys.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 12-28-2008, 10:48 AM   #1693
ToysRUsKid's Avatar
Yeah, i figured that out, i ordered the 34T spool, I already had the 34T rear diff. Thanks.
Old 12-28-2008, 06:25 PM   #1694
Regional Moderator
CarbonJoe's Avatar
Any ideas?
I ground down the pinion setscrew a little so that when it is tightened, none of the setscrew is above the diameter of the body of the pinion. They still hold fine (since the threads above the pinion body aren't contributing anything anyway).
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 12-28-2008, 06:29 PM   #1695
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
any1 know if the fella on ebay thats sellin 008s 400 obo legit, with all these fake/copy stuff goin on?
R
UltegraSTI is offline   Reply With Quote
