Xray T2'008
Old 12-03-2008, 11:16 AM
  #1666
bigkoitat's Avatar
Trader Rating: 6 (88%+)
I just finished building my new 008 and gotta say one of the best cars I ever built!!! Was wondering if the fixed piston or the adjustable piston in the shocks if one is better than the other?
bigkoitat is offline
Old 12-03-2008, 11:19 AM
  #1667
The Evicerator
I prefer the feel of the fixed piston as long as you're fairly settled on a shock setup.
If you envision yourself wanting to do lots of piston hole/dampening feel changes then the adjustable ones are nice for that.
Steve Weiss is offline
Old 12-03-2008, 11:23 AM
  #1668
bigkoitat's Avatar
Thanks Steve, I see what your saying. I think I'll use the adjustable ones for now to see what setting works then use the fixed piston when it's sorted out. Also Steve I want to Thank You guy's at Novak for the great customer sevice and FAST turn around
Old 12-11-2008, 01:00 PM
  #1669
yokemad's Avatar
hi dudes
On most of the latest rubber indoor carpet setup team drivers prefers +0.75 roll centre (lower)
why is that? To get rid off extra steering or grip???
cheers
yokemad is offline
Old 12-11-2008, 07:37 PM
  #1670
markus216's Avatar
Any of you guys trying to sell a 008 to buy the 009?
let me know
-Markus
markus216 is offline
Old 12-12-2008, 04:23 AM
  #1671
RC Huligan's Avatar
let me know
-Markus
RC America and XRAY dealers have lowered their price on the T2'008 since the T2'009 was announced. I don't know how cheap you're looking to go but new T2'008 kits are going for $400 - $450.
RC Huligan is offline
Old 12-15-2008, 09:49 PM
  #1672
Akhor's Avatar
Originally Posted by drsfly View Post
Build it at 1.7 instead of 2.375
Darrald
I've just picked up a 008 EU that was built with the 2.375 drive terrain.
What would be the reason to purchase the other parts to convert it to a 1.7?
Akhor is offline
Old 12-15-2008, 09:59 PM
  #1673
bigkoitat's Avatar
for running the brushless motors 13.5 and 17.5 to get the FDR right. Also with the 34/20 pulleys theres less wear on the belts and the drive train seems more free.
Old 12-16-2008, 01:48 AM
  #1674
RC MARKET's Avatar
Trader Rating: 12 (100%+)
if track is bigger will use 20T center pulley,
but if small track with hair pin ... use 2.375 gear ratio
RC MARKET is offline
Old 12-16-2008, 02:04 AM
  #1675
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by yokemad View Post
hi dudes
cheers
one reason to raise the front roll center is to help the front tires not overheat. more common with tires with larger air gap. (heats up faster) Similar to using the front al stiffener aft of the servo saver.
rx7ttlm is offline
Old 12-16-2008, 06:35 AM
  #1676
Akhor's Avatar
When you change to the 20t you also have to change the front and rear pullies.. Correct?
Akhor is offline
Old 12-16-2008, 06:45 AM
  #1677
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Yes, does anyone know the part number for the cover and gear for the 34t front spool?
ToysRUsKid is offline
Old 12-16-2008, 08:35 AM
  #1678
Akhor's Avatar
What if you did not change this, and instead only change to the 20t.
Could you not just use the higher internal gear ratio of 1.9 (38 Spool / 20t) for your calculations?
Akhor is offline
Old 12-16-2008, 08:44 AM
  #1679
Trader Rating: 40 (100%+)
You would likely need new belts for this....
brians11 is offline
Old 12-16-2008, 08:48 AM
  #1680
BBSpence's Avatar
Trader Rating: 46 (100%+)
305054 is the 34t gear/cover for the diff, multi diff and delrin spool
305184 is the 34t solid composite spool
BBSpence is offline
