Old 10-27-2008, 10:38 PM   #1621
RCknight's Avatar
Default Has anyone used the aluminum center brace on their
008? I run un the vintage class and xray says it helps prevent the car from "stopping" in the corners. I have this issue as well. Should I use the brace or just go with stiffer front springs? The rear of the car is planted so I hate to mess with springs right now.
RCknight is offline   Reply With Quote
Old 10-28-2008, 02:06 AM   #1622
Originally Posted by Drew Ellis View Post
No new car this year or next we will be running the 008 for a while this is because the way the market is and that we are happy with this car there will only be hop up parts like the light weight stuff etc...Not sure on the tray the company you got it from might be better to tell you....Later Drew
I took your advice and went for the '008 all nice it is shining here.... Shame there is now a '009 on the way very shortly... I'd like to personally thank you for your help and not so great adivce...
Cheers.
CouldbeFaster is offline   Reply With Quote
Old 10-28-2008, 06:51 AM   #1623
Originally Posted by RobS View Post
EDIT...
Nevermind...lol
Joe
Real men race MODIFIED!!
JoeGlover is offline   Reply With Quote
Old 10-28-2008, 08:11 AM   #1624
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Cheers.
I don't know Drew but I am sure he was giving information that he thought was correct. With that said we aren't sure if the 009 will be a completely different car yet. It may just be an 008 with all of the upgrades that they have come out with...and maybe a few that they haven't. So your purchase my not be a bad one...yet.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 10-28-2008, 08:31 AM   #1625
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Cheers.
Buying the 008 isn't exactly the worse thing in the world. There are other cars out there that you could have purchased. Unless you are the type that feels I need to have the latest generation of car then yeah you probably have a right to be disappointed.
Now go have fun with the car that you purchased because having fun is what this is all about.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 10-28-2008, 11:01 AM   #1626
RC Huligan's Avatar
Cheers.
XRAY is expected to release more information about the T2'009 by the end of this week. I would imagine it will be months before the T2'009 is available. Plenty of time to enjoy your T2'008.
I help run RCXRAY.com, an online store where XRAY fans buy their RC cars & kits.
RC Huligan is offline   Reply With Quote
Old 10-28-2008, 02:08 PM   #1627
losithrasher's Avatar
ill be grabbing a 008 now, and waiting for a 009.
ONE THINGS FOR SURE ABOUT THE STINGER, NOTHINGS FOR SURE!
losithrasher is offline   Reply With Quote
Old 10-28-2008, 02:47 PM   #1628
Looks like my post came across a little harsh....
I am more than happy with the '008.... Its a lovely bit of kit.... Just a little on the frustrated side just at an announcment a week later after my kit arrived thats all... Im sure won't make much difference to a meer mortal like me anyway...
Hopefully there will be a upgrade kit...
But yes having plenty of fun....
Old 10-28-2008, 03:34 PM   #1629
Hey quick question guys can someone tell me if you must change your camber links to reflect your arm positions when changing roll center? Basically if you run high frnt roll center do you change the camber links to give you high roll center also? Just wandered as it really doesnt state it in the setup book and I didnt know if one could cancel or inhibit the other from giving the full benifit of the change.
NUCRPTRACER is offline   Reply With Quote
Old 10-28-2008, 03:39 PM   #1630
The Evicerator
R/C Tech Elite Subscriber
I usually try to change my camberlink so that it will retain the same amount of cambergain as my previous set up when changing arm mount height.... that way you isolate changes and can know if it did you any good or not... if you don't think about all these things then you're really testing a number of different changes all at once...so it's hard then to pinpoint what did what.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 10-28-2008, 03:40 PM   #1631
KHoff7's Avatar
Changing the camber link position will change camber gain and roll center, To change only the roll center move the lower arms up or down. And no they don't need to be done at the same time if you do both it will actually affect the roll center less if you move both the upper link and lower arm in the same direction.
Try to tune roll centers with lower arms if you want to keep your camper gain the same.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 10-28-2008, 03:52 PM   #1632
Thanks for the quick responses guys....
Old 10-28-2008, 05:12 PM   #1633
P2
P2's Avatar
Trader Rating: 15 (100%+)
You might want to change your avitar too while you're at it
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 11-11-2008, 10:39 AM   #1634
Chris Adams's Avatar
Hey guys,
Just got back from The Big Chill in Jackson Miss. It was my first race using lipo so I was worried about the clearance on the top deck. No worries though. If you have an extra top deck and a dremel, its an easy fix. Your pretty much going to cut the front off right behind the "steering assembly bearing" thing Anyways, put this under your uncut topdeck and shim either the back up 2 mm or cut the other topdecks mounting positions and put them underneath. This worked extremely well and was able to put the 5200 lipos underneath the topdeck with ease.
Chris
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs, Ulti Tires America
Texas EOS 2018!
Chris Adams is offline   Reply With Quote
Old 11-11-2008, 10:43 AM   #1635
GLITTER LIDZ's Avatar
please excuse him, he is a little slow, both on the track and off!
Ken Miller...Team CFX...T2C X-Treme RC Products...RC Driver Magazine
Jack Smiths Sandwich Shops...."They're Stacked"
1NUTZRacing "what in the hell do we need 2 for!?"lol
I played to rough with my "WOODY" and it broke!
GLITTER LIDZ is offline   Reply With Quote
