Old 09-14-2008, 08:06 PM   #1531
Drew Ellis's Avatar
Here is a good tip like Q said if the collar is hard to spin up and down when I first build mine I put a little thin oil on the shock and on the collar thats seems to help and you can do that from time to time ...I spary my shocks with motor spary when I clean them so I put oil on them after that keeps them smooth...Later Drew
RCAMERICA-Xray-Hudy-GravityRC-Kopropo-PROLEVELRC-Team EAM-ORCA-P1Brand-AVID-ProlevelRC Raceway-MOTIV-Max Power America-SRC America
Drew Ellis is offline   Reply With Quote
Old 09-14-2008, 08:12 PM   #1532
mickrcarver's Avatar
Trader Rating: 99 (99%+)
I have used the plastic bodied shocks on my 008's for the whole season and have only rebuilt them 2 times they are very good shocks
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is online now   Reply With Quote
Old 09-16-2008, 09:19 AM   #1533
Drew Ellis's Avatar
RCAmerica has a few things in the works for the Xray 008 we will keep you guys posted when there is some info, just a heads up ...Later Drew
Old 09-16-2008, 09:21 AM   #1534
Trader Rating: 198 (100%+)
Is it a Drew Ellis edition 008?
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 09-16-2008, 12:27 PM   #1535
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Yes agree !
Old 09-17-2008, 03:01 PM   #1536
Send a message via AIM to goop
how about some 8 degree caster blocks
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 09-17-2008, 07:45 PM   #1537
I'm glad they are sticking with this car, because I like it very much! Now I have a reason to get a fresh one .
JHIH is offline   Reply With Quote
Old 09-17-2008, 07:47 PM   #1538
I can make you a set with a heat gun and a protractor .
Old 09-19-2008, 05:20 AM   #1539
Trader Rating: 22 (100%+)
Well I made the switch to Xray and bought a U.S. Version for carpet season. I am wondering however has anyone used this car on Asphalt and what was needed for a descent setup, or is it never going to be as good and I have to get either the EU parts to switch it from season to season. I am glad however they are just tweaking some parts rather than building a new car for 09.
Speed Passion U.S.A. - Turtlemaster Racing
www.speedpasion.net
Anemic_SluG is offline   Reply With Quote
Old 09-19-2008, 09:12 AM   #1540
The US car will not work as well as the EU car on asphalt. You will need the EU chassis, top deck set and rear belt. The plastic parts on the US is harder than the EU. Hard vers extra hard. You can replace all the plastic parts also. The US uses 50mm drive shafts while the EU uses 52mm. You do not need to replace these. The longer driver shaft is to give more traction. You will also want a spool for the front. The multi diff is nice. But the plastic spool works well. The plastic outdrives can break. But some new aluminum outdrives will be out soon.
Also the new black springs are nice.
This is a less expensive conversion turning a US car into a EU car. Plus you have 2 different cars depending on what tire type you want to run.
www.donatelife.net
Old 09-19-2008, 09:16 AM   #1541
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
http://www.teamxray.com/teamxray/news/newsdesc.php?news_id=738&kategoria=738&catName=New %20T2\'008%20Alu%20Solid%20Axle%20Driveshaft%20Ada pters&Xnet_Session=5587e8f6b62683a716b4f95134f5065 f
305136 T2'008 Alu Solid Axle Driveshaft Adapters (2) - Hard Coated
"CNC-machined diff drive shaft adapters for XRAY T2’008 Composite Solid Axle, made from premium lightweight Swiss 7075 T6 aluminum."
"The alu driveshaft adapters for the front solid axle are a direct replacement for the stock composite versions but with increased the strength and lifespan."
"The modular design of the front solid axle allows for easy removal and servicing. Internal slots key to drive shaft pins require use of driveshaft blades #305241 (included), enabling direct power transfer to the wheels and eliminating excess play between the outdrives and drive shafts. Set of 2."
"Precision machined with highest tolerances using premium fully-automatic German CNC-machines. High-quality hardcoating is done at XRAY’s own in-house fully-robotic hardcoating line, ensuring a perfect hardcoated surface every time."
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 09-19-2008, 09:19 AM   #1542
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
I've been wondering how to do it also since I'd like to do carpet and asphalt. maybe this should be a sticky someplace..."How to convert the US T2'008 for asphalt".
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 09-19-2008, 12:59 PM   #1543
RC MARKET's Avatar
Old 09-20-2008, 12:15 PM   #1544
Szimon's Avatar
Default pinions
Hi experts,
I'm going to race with t2k8 this winter in super stock (17,5T brushless). I'll race on technical course on a carpet.
Could anyone recommend me the range of pinions? I know this is not easy to say it.... thanks a lot
Szimon is offline   Reply With Quote
Old 09-20-2008, 12:52 PM   #1545
adamge's Avatar
Something like evens 40 through 54 should get it done.
-Nietzsche
