Old 09-13-2008, 11:47 PM   #1516
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
From my understanding the new car won't have any major changes (like what happened past 2 years) but it will be the same with the new items on the xray column
A conversion kit would be also available I believe
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is offline   Reply With Quote
Old 09-14-2008, 07:18 AM   #1517
Drew Ellis's Avatar
There will be NO new car this year just upgrades and those will noy be put into kits they are just upgrades like mostly lightweight parts and those will be out soon...The current car they are really happy with and the way the market is right now we thought that it would be the wise thing to do so the idea is to run the T2 008 two or more seasons that means 24 months or more before the next car....Thanks Drew
RCAMERICA-Xray-Hudy-GravityRC-Kopropo-PROLEVELRC-Team EAM-ORCA-P1Brand-AVID-ProlevelRC Raceway-MOTIV-Max Power America-SRC America
Drew Ellis is offline   Reply With Quote
Old 09-14-2008, 08:03 AM   #1518
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Originally Posted by yokemad View Post
Tamiya shocks Better than both
because long time same sixe , so all peoples can easy to setup & had tips !
Old 09-14-2008, 08:47 AM   #1519
yokemad's Avatar
Some people even prefer plastic shocks over alloy ones LOL
yokemad is offline   Reply With Quote
Old 09-14-2008, 01:55 PM   #1520
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default race
wheres the next race?
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 09-14-2008, 01:56 PM   #1521
Shop Owner
nnick's Avatar
As I have used all 3 I must say that the plastics ones are not as good as the alloy or tamiya ones. Basically problems lies on the fact that after 2-3 runs they need to be rebuild, while the other two don't need after many runs.
Being not a pro driver having to build so often shocks isn't something I like nor have time to do it, so the alloy ones are a must for me
Nikolakopoulos Nick
RC RING
Enjoy RCing....
R/C Tech #82
IRT #123
Old 09-14-2008, 03:03 PM   #1522
Drew Ellis's Avatar
I would just like to say I have always used the plastic and I do not build them every 2 or 3 runs maybe race to race depending on how long there is from race to race if you have to build every 2 to 3 runs you are doing something wrong and I have tested the shocks and there is no diff...Drew
Old 09-14-2008, 06:12 PM   #1523
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
How often should someone wait to check their shocks if they run every week?
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 09-14-2008, 06:30 PM   #1524
Drew Ellis's Avatar
It is good to check them at every race but I do not think a rebuild is something that needs to be done..I have raced a whole season with just putting new oil in...Travis has ran the same shocks oil,bladders.o-rings since the novak 08 so thats three races in a 8 month span and we just rebuildt them at the IIC this year..So checking them is good but a rebuild not needed..The way I check them is just seeing the rebound as long as the front is the same side to side and the rear is the same side to side your good...Here's a quick way to build them fill them up put the bladder in the cap and put it on tighting as tight as you can usually you can not push the shaft in then you bleed from the cap at the bottom being careful when you push the shaft in to not let it come out before you tighting the cap at the bottom, just make the rebound the same for all for shocks..I run 50% on foam carpet and 100% for rubber carpet or asphalt...Hope that helps Drew
Old 09-14-2008, 06:51 PM   #1525
KHoff7's Avatar
Whats a good spur pinion combo for 3.5 fdr and a 4.5 fdr for the 008. Either drive train combo would be fine but I guess the 20/34 would be better for the tall gearing needed to be achieved. Thanks.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 09-14-2008, 07:38 PM   #1526
yokemad's Avatar
If Shocks Loose Rebound like 100% to 80-85% after 2 weeks or 10x5min Race
is that normal or Do you think O rings has to be replaced with the new ones?
Cheers
Old 09-14-2008, 07:48 PM   #1527
Drew Ellis's Avatar
A xray 104 would work 39/104=4.53....50/104=3.53 but it is really tight 49 will be ok..If you do not want xray spur rw makes a 100 and that will be fine for both and it fits the car nexus racing has them...Later Drew
Old 09-14-2008, 07:51 PM   #1528
Drew Ellis's Avatar
Cheers
Yes thats ok as long as there the same side to side front to rear if anything just new oil The o-rings still good,same o-rings in mine for the last year..Later Drew
Old 09-14-2008, 07:57 PM   #1529
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
I agree the plastic XRAY shocks are great. I have went over 50 runs and still had very consistent rebound. I also agree that there does not seem to be a performance difference between the Aluminum and the Plastic version. The only reason I might advise the switch is for the durability of the threads. Sometimes (especially outdoor) when the threads of the shocks get dirty they tend to wear and even get distorted enough to become difficult to adjust.
I check after each race day.
mrrcguy is offline   Reply With Quote
Old 09-14-2008, 08:01 PM   #1530
Regional Moderator
mrrcguy's Avatar
Why not hit the XRAY Challenge Event in Jonesboro Arkansas next week.
Here is the tread
http://www.rctech.net/forum/msra-mem...mid-south.html
