Old 05-07-2003, 08:44 PM   #46
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
while your at it why dont you spray your controler green too same with your batteries then do the whole car
Calvin Ng is offline   Reply With Quote
Old 05-07-2003, 08:47 PM   #47
dynoman007's Avatar
Send a message via MSN to dynoman007 Send a message via Skype™ to dynoman007
Default hmmmm
i may do that thx for the tip ............
dynoman007 is offline   Reply With Quote
Old 05-07-2003, 08:48 PM   #48
dynoman007's Avatar
Default heyyyyyy
got any green paint i can have ??
Old 05-07-2003, 08:51 PM   #49
Regional Moderator
R/C Tech Charter Subscriber
Default Re: hmm
Originally posted by dynoman007
is that a good thing ?????
why yeah its all good just means bro you got alot of cash
and you use it like a wall covering
Ko Racer is offline   Reply With Quote
Old 05-08-2003, 12:13 AM   #50
Registered User
Just bench test the car to see what happens when the belt is moving. It should not be a problem. If you have seen pics of Surikarn's 414MII you will notice no Belt tensioner used.
Steevo, You're wrong. Surikarn's 414mII does have belt tensioner. Check it out. http://www.teamorion.com/live/results-cars.asp?id=133
The pic is under Friday May 17th round 2
Aku-Man is offline   Reply With Quote
Old 05-08-2003, 12:24 AM   #51
Steevo's Avatar
Sorry to say but I have 2 pics of it in 2 different RC Mags that clearly show no Belt tensioner. Also I have a pic of a TRF414MII used by David Jun with no tensioner on it as well.
You work it out
Calvin,
The best thing for you to do is try the car without tensioner and see what you think.
I found not using a tensioner on My TA04R and Xray had no negative effect at all.
The best way to learn is to experiment with your car and see what suits you best. By testing these things you get to learn about your car more. Its not going to damage the car in any way so give it a try and make your own decision.
Steevo
Steevo is offline   Reply With Quote
Old 05-08-2003, 07:28 AM   #52
Registered User
Calvin Ng's Avatar
i tryed it and it didnt make any noticable diffrence but i'm sure it did inside
Old 05-08-2003, 08:08 AM   #53
Surikarn's 414 used a belt tensioner at the worlds, i know i have held the car. Rick
Rick Draper is offline   Reply With Quote
Old 05-08-2003, 09:36 AM   #54
Registered User
Calvin Ng's Avatar
but if you dont need it should i use it???
Old 05-08-2003, 10:54 AM   #55
Registered User
Totally up to U.
Rick, how did Surikarn mount his servo? I don't see he use servo stand and how did he put antenna stand on lower chassis? I think he mount it on the hole for servo stand?
Old 05-08-2003, 12:56 PM   #56
He cut off the bit that stickes out on the chassis to mount the servo and then cut the lugs off the servo and glued it further forward and closer to the center than on a std car. I cannot remember where the antenna on the lower chassis, i think he probably just drilled another hole for it. Rick
Old 05-08-2003, 03:06 PM   #57
Default surikarns chassis
hey rick, i was wondering.... in some pics of surikarns car, he's got this white looking stuff under the electronics and steering bell cranks. could you tell me what it was?
TRF414WCR is offline   Reply With Quote
Old 05-08-2003, 03:13 PM   #58
dynoman007's Avatar
Default 414
that is aluminium under the steering posts etc.. for stiffness i believe it was a pretty good size if i rem correctly milled for the rear front block to sit and went back a lil past the steering posts
Old 05-08-2003, 03:28 PM   #59
Registered User
Calvin Ng's Avatar
when you have the servo closer to the center doe sit make a diffrence
anyone have pics of his car?
Old 05-08-2003, 10:52 PM   #60
dsrbltoys's Avatar
This is Suri's car at TCS Worlds. On permanant display in Japan.
dsrbltoys is offline   Reply With Quote
Carbon Fiber HK Racing Joe Electric On-Road 7 01-24-2006 03:33 PM
carbon fiber dakrat Painting, Designs, Graphics and Photography 4 05-06-2005 08:50 PM
4mm carbon fiber ksj44 Electric On-Road 3 04-11-2005 02:45 PM
Carbon Fiber DPowell R/C Items: For Sale/Trade 10 01-19-2004 07:20 AM
Mission Carbon, One-ways, Threaded shocks rayhuang R/C Items: For Sale/Trade 4 07-15-2002 07:47 PM
