Old 05-05-2003, 09:25 PM   #16
Registered User
can you show me parts of the belt tensioner.what does the belt tensioner do????????
Adjust belt's tension. The original 414mII only have one on lower deck. When you push the throttle, you will see the belt wabbling up and down. Which the power transfer can loss over there and unstable. I add one on upper deck like WCR to fix the problem. I use Square belt tensioner, but I bought the wrong color.
Aku-Man is offline   Reply With Quote
Old 05-05-2003, 09:29 PM   #17
Registered User
can you give me the part number for the new one way????
53612
Old 05-05-2003, 09:48 PM   #18
JimmyMac's Avatar
Also on the SSG chassis the batteries are even closer to center! Just another note......
JimmyMac is offline   Reply With Quote
Old 05-05-2003, 09:51 PM   #19
Registered User
Yap, his right. I just check with my original. I didn't notice that before.
Old 05-05-2003, 10:40 PM   #20
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
can you give me the part number and the picutres of all the belt tensioners you go
Calvin Ng is offline   Reply With Quote
Old 05-05-2003, 11:40 PM   #21
Registered User
The pic is Square belt tensioner for 414.
SSG set: 49272, 49273, 49274, 49275
Lightweight Bulkheads: 49269, 49270, 49271
Old 05-06-2003, 01:32 AM   #22
my friend has the bulkheads and the ssg chassis and his car is now super light. as for my M2 i polished the bulkheads and you might have seen in the 414 thread
Chris@WeaponR is offline   Reply With Quote
Old 05-06-2003, 07:31 AM   #23
Registered User
Calvin Ng's Avatar
no i havent can you show me?
Old 05-06-2003, 09:57 AM   #24
dtm
dtm's Avatar
Send a message via ICQ to dtm
Yes...the SSG is most definately more flexible. Even the 3mm SSG shock towers are more flexible than 2.5mm normal carbon.....I noticed this immediately with my TA04 parts!
dtm is offline   Reply With Quote
Old 05-06-2003, 11:58 AM   #25
Registered User
Calvin Ng's Avatar
where do you put the square belt tensioner??????????
is it for the long big belt for the short belt
Old 05-06-2003, 12:18 PM   #26
Registered User
For long belt. The original 414 upper deck doesn't have that hole for extra tensioner. Only WCR and SSG does.
Old 05-06-2003, 04:25 PM   #27
Registered User
Calvin Ng's Avatar
oh ok i might have to get the carbon fiber peice then!!!!!!!!
Old 05-06-2003, 04:33 PM   #28
Registered User
Calvin Ng's Avatar
i dont get how it works?????
can someone give me a pic???
Old 05-06-2003, 05:49 PM   #29
Steevo's Avatar
Hi Guys,
Just thought I'd throw something in here.
I am not completely familiar with the belt tensioner set up for the 414MII but is it really necessary to add an extra one?? It is actually better to run your car with no tensioner as your drivetrain will work better.
Unless your belt is skipping then I would say don't use one. They just add another point of friction in the drivetrain.
Belt drive cars are actually more efficient at full speed when the belts rise off the pulleys slightly therefore creating less friction.
A tensioner usually prevents this to some extent.
So in the end unless you really need them to prevent skipping the maybe do without them.
Just my opinion
Steevo
Steevo is offline   Reply With Quote
Old 05-06-2003, 07:18 PM   #30
Registered User
Calvin Ng's Avatar
what do you mean by skipping?
Carbon Fiber HK Racing Joe Electric On-Road 7 01-24-2006 03:33 PM
carbon fiber dakrat Painting, Designs, Graphics and Photography 4 05-06-2005 08:50 PM
4mm carbon fiber ksj44 Electric On-Road 3 04-11-2005 02:45 PM
Carbon Fiber DPowell R/C Items: For Sale/Trade 10 01-19-2004 07:20 AM
Mission Carbon, One-ways, Threaded shocks rayhuang R/C Items: For Sale/Trade 4 07-15-2002 07:47 PM
