40fm futaba micro reiever-how long should the antenna be? >
Old 05-06-2003, 04:39 AM
Default 40fm futaba micro reiever-how long should the antenna be?
how long should the wire be?
deanspoors is offline
Old 05-06-2003, 04:52 AM
hi there,
i worked it out to be 470mm or 230mm.
if anyone is wondering how you work it out:
>wavelength = velocity / frequency
velocity is the speed of light
put some numbers in
>wavelentgh = 3e8 / 40 e 6
= 7.5m
then you need to keep dividing by 2 until you get a nice manageable length. in this case 7.5m /16 or 7.5m / 32
and it is the same length as the wire on a fuataba!
hope that helps
sanj
schumacher is offline
