Digital servo
Old 05-06-2003, 09:55 PM
Suspended
Default Digital servo
I thinking of getting a new one but not sure witch one. do you guys know? Im looking to spend up to 120 for one.
R C king is offline
Old 05-06-2003, 10:05 PM
icon's Avatar
what are you using it for?
icon is offline
Old 05-06-2003, 10:07 PM
Carbon_Fibre3's Avatar
i would go for the ko 2123, good speed, good torque,
if u search, u will find a thread about this very topic. i think the guys in there recomended this one.
Carbon_Fibre3 is offline
Old 05-06-2003, 10:11 PM
icon's Avatar
i'm partial to futaba and airtronics only because great planes supply replacement parts. unless of course if horizon has good support for JR/KO Propo
icon is offline
Old 05-06-2003, 11:08 PM
dtm
dtm's Avatar
For normal use KO 2143 is very good...you don't have to bother with the additional FET wire of the 2123.
I have been using the Futaba 9451 lately...not as fast as the 2143 (0.1s) however, it is very well made and also worth considering.
dtm is offline
Old 05-07-2003, 10:16 AM
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Thumbs up .
Don`t forget the good old Futaba 9550
-Dave
JDM_DOHC_SiR is offline
Old 05-07-2003, 10:38 AM
kaizen's Avatar
running electric and using it for steering? definately the ko 2143! excellent, fast, recenters well, and holds/tracks consistently very straight!
kaizen is offline
Old 05-07-2003, 10:44 AM
Suspended
I am useing it on my T3 and I need one i think because my servo with servo saver is hittig and it wont turn left as much as rigt. Did anyone elese have this poblam? and can i get metal gear for a standerd servo? THANKS>
R C king is offline
Old 05-07-2003, 01:39 PM
did you said that you have a servo saver on the actual servo? if you do, you dont need one on the actual servo, the T3 has a built in servo saver.
micro speed is offline
Old 05-07-2003, 05:22 PM
traxxasdude's Avatar
I think your problem is your servo saver. Unscrew the servo saver and there should be little teeth on the actual servo. reposition the servo saver so that nutrual is nutrual for the servo also.
traxxasdude is offline
Old 05-07-2003, 06:22 PM
pimpedaccord's Avatar
Trader Rating: 25 (100%+)
JR 8450
188 oz/in
.09 s
Kicks any other servo's a$$
$105
pimpedaccord is offline
Old 05-07-2003, 08:29 PM
Suspended
I didnt have a servo saver until i broke one of my servos. Sould i take it off.
R C king is offline
Old 05-08-2003, 02:56 PM
A servo sasver is the part that connects it to the shaft, turnbuckle, etc. all servos have one and will not work without one.
Old 05-08-2003, 03:58 PM
Im2lazy's Avatar
there are also servo horns, which you are forgetting.
Some people run steering servos without servo savers (dumb, but whatever they want ), and many cars have built in servo savers.
R C king, did your servo have metal gears? For off road, you should have them.
Im2lazy is offline
Old 05-08-2003, 05:59 PM
Korey Harbke's Avatar
If your really good and you dont hit walls at all (which we all do) you can run with a solid aluminum servo arm. All power from the servo goes to the ground, but you run a major risk of messing up your servo.
Korey Harbke is offline
