Old 05-04-2003, 10:12 PM   #1
TAO4R's Avatar
Metal diff pulleys
Do metal diff pulleys make a big difference. i have a TA04 and i took apart one of the diffs today and it was striped. du think that i should replace it with a metal one or a plastice one?
TAO4R is offline   Reply With Quote
Old 05-04-2003, 10:32 PM   #2
Default Re: Metal diff pulleys
plastic is better! less drag and helps motor to run at a better rate car should be quicker and have more punch and could give more run time ..... It's all about making the car run free with little or no drag.. have fun..
Mark Barden .
mb racer is offline   Reply With Quote
Old 05-04-2003, 10:39 PM   #3
TAO4R's Avatar
cool that will help alot and save $$$$
Old 05-04-2003, 11:11 PM   #4
Mark Barden .
Old 05-04-2003, 11:11 PM   #5
Registered User
I have Tamiya alum. pulley on my 414 and they sure are heavy. I'm thinking about change it back to original black plastic pulley on front, but keep the alum. on rear.
Aku-Man is offline   Reply With Quote
Old 05-04-2003, 11:24 PM   #6
sounds ok! alittle more weight in the rear will help with tracksion and front should spool up a little quicker making the front of the car pull harder,, good for those turns. and sweepers.. just drive it like you stole it...and have fun....
Mark Barden .
Old 05-05-2003, 05:49 AM   #7
Trader Rating: 69 (100%+)
i replaced the plastic pulleys in my 414 with aluminum ones. the metal ones are indeed heavier but i run in a dusty & dirty track. the metal ones seem to hold up better than plastic and theyre easier to clean - the black bits of dirt are easily seen against the silver pulley
marvi is offline   Reply With Quote
Old 05-05-2003, 05:52 AM   #8
Barry White's Avatar
These also will not melt when your diff would happen to spin.
Barry White is offline   Reply With Quote
Old 05-05-2003, 10:05 AM   #9
dtm
dtm's Avatar
Send a message via ICQ to dtm
The metal pulleys have plastic inserts for the balls.....these will melt instead!!
dtm is offline   Reply With Quote
Old 05-05-2003, 11:11 AM   #10
Registered User
That's why I keep the rear to prevent heat up. I think the insert will stay longer using alum. pulley like heat sink. Front don't have diff ball.
Old 05-05-2003, 04:54 PM   #11
Dtm, you are wrong. The inserts are made of teflon and you can put them on your soldering iron without melting.
Old 05-05-2003, 09:37 PM   #12
dtm
dtm's Avatar
You can??! .....I'll try that next time!!
Old 05-06-2003, 02:51 AM   #13
Vic
Vic's Avatar
I had very good experience with the alu. ones at he rear as well.
They definitely do not melt but they ware-out.
Can actually someone tell me where can you buy only the teflon bushings?
Thanx
Vic is offline   Reply With Quote
Old 05-06-2003, 05:12 AM   #14
The bushings have a long order number, they are listed in a 414M manual.
Old 05-06-2003, 06:25 AM   #15
Vic
Vic's Avatar
I do know the order number, unfourtunately I do not know where to get them from!
Metal Diff Gears - Your input please... needrcspeed Micro and Mini Scales 4 12-01-2006 05:19 PM
trf415 MRE Diff pulleys in MSX Stevem9 Electric On-Road 5 11-13-2006 06:49 PM
V ONE RR PULLEYS mitch_0139 Australia Wanted to Buy 0 03-21-2006 10:57 PM
WTB XXX-S Pulleys Xtant3150c R/C Items: Wanted to Buy 0 04-17-2004 10:59 PM
