Old 09-06-2007, 03:07 PM   #121
rosko's Avatar
does anyone one know if you have to make any setup changes from your previous setup with the dish wheel to the bigger rim to compensate for the larger dia. or is it not necessary ? please explain
rosko is offline   Reply With Quote
Old 09-06-2007, 07:04 PM   #122
Rosko,
If anything these rims/tires will plant the car a little more. You shouldn't have to make any adjustments to go faster.
punkboy is offline   Reply With Quote
Old 09-06-2007, 10:11 PM   #123
rosko's Avatar
thanks for the reply punkboy any other opinions , comments, or experinces will be appreciated.
Old 09-06-2007, 10:42 PM   #124
Gravity RC
I would have to agree with Robbie, their may be a slight tweak here or their that the tire may allow you to do differently but for the most part i think the set-ups will be very similar. paul
Paul L is offline   Reply With Quote
Old 09-06-2007, 10:53 PM   #125
I think we will know more after this weekend. We have some of these going out to dealers, distributors and our drivers. By Sunday night I should have gotten a lot more feedback. So far, the general attitude is that they drive easier, but run faster laps. Perhaps it is because they are easier to drive that translates into faster times???? Also, they are very light (lighter than even the 26mm 2-stage tires) so they accelerate quickly. I think having a few more compounds to choose from also helps to dial in the car.
Jack Rimer is offline   Reply With Quote
Old 09-06-2007, 11:10 PM   #126
AdrianM's Avatar
Jack - Will you be selling a Double Pink Prism Rear tire?
I am sure you guys are working on a website update but in the mean time can you post part numbers for the front and rear compounds on Prism rims so we can tell our local hobby shops what to order?
Adrian Martinez
Old 09-07-2007, 04:54 AM   #127
Trader Rating: 45 (100%+)
Jack posted the part numbers on the prior page. Here you go.
Originally Posted by Jack Rimer View Post
6130- pink
6132- magenta
6135- double pink
6138- lilac
6140- purple
6160- double pink/orange
Apex is offline   Reply With Quote
Old 09-07-2007, 05:57 AM   #128
I think we will be doing a double pink rear. We make it, we just have not assigned a part number for it.
Old 09-07-2007, 02:16 PM   #129
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Is there pics of prism sedan and 12th scale tires? none on Jaco's site for some reason.......
Will the new prism tires still have teh stage 2 compound?
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 09-07-2007, 04:28 PM   #130
AdrianM's Avatar
Yeah but are those fronts or rears?
Adrian Martinez
Old 09-07-2007, 04:29 PM   #131
AdrianM's Avatar
Cool, I really like running double pink front and rear on asphalt.
Adrian Martinez
Old 09-07-2007, 04:58 PM   #132
timmay70's Avatar
The pink, purple, etc rubber is actually MORE dense than the white, gray, etc. The cell structure is more hardness dependent than anything. A pink is more open pored than a purple even though they are in the same family of rubber. A white is more porous than a gray for the same reason.
The pink, purple, etc tires ARE actually gas rubber. We use these for rears only. The front rubber for gas is completely different and doesn't work well on carpet.
The white, gray, yellow family relies more on traction compound for bite than the the pink, purple family. Those tires heat up and create bite.
Jack, am I correct in thinking that the two families break down something like this:
Heat induced grip:
pink, magenta, purple, lilac, cyan, double pink
compound induced grip:
gray, yellow, black, white
thanks.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 09-07-2007, 07:25 PM   #133
Heat induced grip:
thanks.
Yes. That may be oversimplifying it, but you could say that. Stock cars tend to need to be freer so a gray or yellow rear is a little faster than a pink or double pink in many situations. Mod cars crave grip so pink works well there. Ultimately, it depends on the track.
Old 09-07-2007, 07:32 PM   #134
AdrianM's Avatar
Sorry guys I have to apologise...I had 1/12th scale on the brain when I posted my question
I was asking about double pink Prism 1/12th rears.
Adrian Martinez
Old 09-07-2007, 07:41 PM   #135
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
The new Prism's use a larger wheel and are not 2 stage tires. Its not needed. I got to compare the Prism's to the old 2 stage stuff a few weeks ago....Prism's were better in every aspect for me..
EA
EAMotorsports is offline   Reply With Quote
New Parma and Jaco Sedan Foam tires Bigdaddyswank R/C Items: For Sale/Trade 4 04-04-2008 01:15 PM
JACO Sedan Foam Tires ORANGE DOG R/C Items: For Sale/Trade 12 03-28-2008 06:29 PM
Jaco 26mm 2-stage Sedan Foam Tires.. BSchorr R/C Items: For Sale/Trade 9 12-17-2007 08:00 PM
10 Pair Jaco 1/10 Sedan Foam Tires JAC5156 DBL Pink 2 Stage 26m donny R/C Items: For Sale/Trade 3 09-10-2007 08:55 PM
Jaco Sedan Foam Tires Ginsu R/C Items: For Sale/Trade 7 01-24-2006 01:21 PM
