Old 09-30-2007, 07:34 AM   #151
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
Jack,
You have a pm.
1armed1 is offline   Reply With Quote
Old 10-06-2007, 01:10 PM   #152
SlamMan's Avatar
Jack or anyone, what tires would you suggest for running modified foam on asphalt? We've been trying the Nitro shoes but it's tough to get any steering with them. I'm guessing some of the TC tires might work better. What would work good without wearing out too fast. I would imagine something like double pink would wear out pretty quickly.
Michael H
OnRoadColorado.com
Colorado On Road RC Club
SlamMan is offline   Reply With Quote
Old 10-06-2007, 02:48 PM   #153
the lilac is a 38 shore tire, that might be your best bet on asphalt with tire wear and traction.
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 10-06-2007, 04:16 PM   #154
SlamMan's Avatar
Thanks, Jeff.
Michael H
OnRoadColorado.com
Old 10-06-2007, 06:31 PM   #155
steveM3's Avatar
Default .
The new Jaco sedan tire is awesome. I found it much better than the wagon wheel wrap.
Originally Posted by TJ Bradley View Post
The Prism's worked perfect for me also.
steveM3 is offline   Reply With Quote
Old 10-08-2007, 08:35 AM   #156
Originally Posted by mcsquish View Post
Jack, will the Nitro Shoes be going to these rims? The current rims are ok, but the Prism rims are different than anything out there.
Yes. We are working on a very interesting Prism design for nitro. Stay tuned....
Jack Rimer is offline   Reply With Quote
Old 10-08-2007, 08:41 AM   #157
Originally Posted by swopemike View Post
So can you give some guidelines, for instance
for stock and 19T
(1) on a typical club track, 36 x 60, mix of tight and flowing sections, Jack the Gripper only, grip is low most of the time, maybe low to medium at the trophy races
(2) a track like The Gate, or Cleveland Nationals, using Paragon or open compound choice, grip usually med to high even very high
I'm just trying to figure out which tires to start with that get me in the ballpark most of the time. Also if I am going to ask my LHS to order these, I want something that is likely to work for most of our locals too.
I would start with double pink (6135) all the way around. Perhaps glue the edges of the front tires with CA to take away a little steering. Work with the car before dialing it in with tire compounds. When you get it good, then fine tune it with other compounds. You may also want double pink/orange (6160) on the front if the steering is too sensitive with the double pinks.
Old 10-08-2007, 08:44 AM   #158
Lilac is good, but I would run purple if you can. It will wear better (especially on the front). The nitro tires may work if you run very soft (35) fronts with firm (42) rears.
Old 10-08-2007, 08:48 AM   #159
1armed1's Avatar
Jack,
you have another pm.
Old 10-08-2007, 08:48 AM   #160
Suspended
Ass Toot's Avatar
How did the new sedan wheel design perform out at the IIC?
Haven't seen anybody mention it.
Ass Toot is offline   Reply With Quote
Old 10-08-2007, 09:06 AM   #161
SlamMan's Avatar
Thanks, Jack. I'll give those a shot.
Michael H
OnRoadColorado.com
Old 10-08-2007, 09:26 AM   #162
Quite well, actually. We had 7 out of 10 mod drivers on our tires. We TQ'd and won 19 turn (on 2-stage), and we got 2nd in stock. We won stock 1/12 and mod 1/12 and TQ'd both classes. There were more A-main drivers on JACO foams than any other brand. According to the hobby shop, JACO outsold the next leading brand at least 10 to 1. All in all, considering the success of our rubber tires too, it was a fantastic weekend for us.
Old 10-08-2007, 09:42 AM   #163
James35's Avatar
Well fellas,
I hate to be the bearer of bad news, but the JACO 1/12th Prisms flex too much for 1/12th oval. The outer 5 spoke area is fine, but the inner portion of the wheel flexes too much. To my surprise, I discovered that the bottom of the kingpin touches the wheel under compression. The kingpin had worn a groove into the wheel. To confirm this yourself, put a 0.20" spring in, using your thumb, push the tire up, the wheel flexes and the kingpin touches the wheel. (This does not happen with the other 38mm competing manufacturer wheels.)
The Prisms work fine for the other 3 wheels, but currently, I can't use them on the right front (at least when it comes to oval, I have not tested for road course).
James35 is offline   Reply With Quote
Old 10-08-2007, 09:46 AM   #164
Suspended
Ass Toot's Avatar
Thumbs down
Did you TQ and/or win? Stacking the field by giving tires to at least 70% of all mod sedan entries isn't impressive.
Not the new wheel, as I asked about. How about the rest of the 19 turn field? Didn't see you mention that as you proudly did in mod.
Did you TQ and/or win? How about the rest of the stock field? Didn't see you mention that as you proudly did in mod.
Not the new sedan wheel, as I asked about.
Old 10-08-2007, 09:58 AM   #165
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
mr. toot - jacos were sold 10:1, but another tire got 8 of the top 10 spots in stock sedan, and 7/10 in 19t and TQ/WINS in stock and mod foam. not sure who was buying all of the jacos up, but it wasn't the guys in the sedan mains.
- bill jordan -
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
New Parma and Jaco Sedan Foam tires Bigdaddyswank R/C Items: For Sale/Trade 4 04-04-2008 01:15 PM
JACO Sedan Foam Tires ORANGE DOG R/C Items: For Sale/Trade 12 03-28-2008 06:29 PM
Jaco 26mm 2-stage Sedan Foam Tires.. BSchorr R/C Items: For Sale/Trade 9 12-17-2007 08:00 PM
10 Pair Jaco 1/10 Sedan Foam Tires JAC5156 DBL Pink 2 Stage 26m donny R/C Items: For Sale/Trade 3 09-10-2007 08:55 PM
Jaco Sedan Foam Tires Ginsu R/C Items: For Sale/Trade 7 01-24-2006 01:21 PM
