Old 05-04-2003, 01:46 PM   #1
doublest's Avatar
Send a message via MSN to doublest
Default LRP Discharger??
Automatic discharge termination: 5.0 Volt residual
voltage
Does this discharge ok. and stop without fully discharging.
doublest is offline   Reply With Quote
Old 05-04-2003, 09:42 PM   #2
Suspended
Yeah i have tried one and they work good. But I can't find them here in the US.
R C king is offline   Reply With Quote
Old 05-04-2003, 09:44 PM   #3
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
hey doublest i've read alot of your posts. as im a newbie too
arent you getting 3300's their is not point discharging them if your going to discharge them
i rather get 2400's for stock. i made the wrong choice. but when i get good enough i want to get into mod.
i got 3300's gp's and sanyo's
whatever you do dont get sanyo's they SUCK for stock no punch what so ever
Calvin Ng is offline   Reply With Quote
Old 05-04-2003, 09:52 PM   #4
TAO4R's Avatar
I have an old apex discharger from a friend's old rc stuff. what does it do???
TAO4R is offline   Reply With Quote
Old 05-04-2003, 10:23 PM   #5
TAO4R's Avatar
Like what is a discharger and what does it do. it has a few different selection on it. it says 6 7 and 8 cell and deep discharge and normal discharge???
Old 05-04-2003, 10:25 PM   #6
Suspended
A discharger will drain your packs. It is a good thing to have
Old 05-04-2003, 10:41 PM   #7
TAO4R's Avatar
so it drains the batts so you can charge it up more??? It will also make the battery run longer right??? if so what setings should a put it one. 6, 7 or 8 cell for a 7.2 V batt???
Old 05-04-2003, 11:30 PM   #8
TAO4R's Avatar
right???
Old 05-05-2003, 07:17 AM   #9
doublest's Avatar
Default Back to the point
Lol back to what i first posted.
has anyone used this and is it good enough to use at races, so basically does it discharge quickly otherwise i cant discharge between races.
So i take it, u just have to wait for the light to go off, then its done. Am i right???
Old 05-05-2003, 04:19 PM   #10
Suspended
You should have enough time to discharge te pack after the race. but have one more pack charged just in cas but it is a fast dischager like all of them.
Old 05-06-2003, 08:15 AM   #11
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
A discharger is basicly like running your pack, without running your car. It will draw current out of your battery pack, and run it through some resistors, instead of running through the motor of the car.
You will want to set your discharger to 6 cell for a 7.2 battery. If you are ever curious, (1.2 x #cells = pack voltage)
Automatic discharge termination: 5.0 Volt residual means that the discharger will stop discharging the battery pack when it reaches 5.0volts. This should be fine, as most racers set thier dischargers to about 5.40v
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 05-06-2003, 09:08 AM   #12
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Troy, don't you mean .9/cell or 5.40 Volts?
John Fontaine is offline   Reply With Quote
Old 05-06-2003, 12:28 PM   #13
RCTech Member #2
TSR6's Avatar
Yes, I mis-typed. Thanks for catching that, I'll edit the post.
Troy
RCTech Member #2
Old 05-14-2003, 11:50 AM   #14
doublest's Avatar
On the LRP Discharger do i have to wait till the light goes completely out, or when its dim.
Cheers
what's the diff btwn 0-30 discharger & novak smart discharger straightaway Electric On-Road 9 09-12-2006 07:15 PM
Wanted: Discharger and/or Discharger building info oMONSTERo R/C Items: Wanted to Buy 7 06-20-2006 06:24 AM
is this discharger a good one? Venom Battery Discharger aquito Electric On-Road 6 05-09-2006 02:21 PM
Duratrax 20 Amp Discharger, Indi Zerothirty-030 Discharger NOTFASTENOUGH R/C Items: For Sale/Trade 8 05-05-2006 08:07 PM
Wanted Integy Octane 2 Discharger or Trinity Realtime 2 Discharger FUK_WRX R/C Items: Wanted to Buy 0 08-02-2003 05:23 AM
