Old 05-04-2003, 12:42 PM   #1
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
Default removing CA from tire
when i was glueing my tire i got a small drop of that ca stuff stuck on the tire
is there any way i can remove it?????
Calvin Ng is offline   Reply With Quote
Old 05-04-2003, 12:48 PM   #2
traxxasdude's Avatar
maybe there is some acid that will get off the glue but I think that super glue remover would work the best
traxxasdude is offline   Reply With Quote
Old 05-04-2003, 12:49 PM   #3
Registered User
Calvin Ng's Avatar
whats super glue remover????
would alchol damage the tires if i try it
Old 05-04-2003, 12:54 PM   #4
super glue remover is stuff that you can find at the super market by the super glue that will remove super glue.
alchohole might damage your tires depending on what compound. If it is soft, I would use it conservately but if its hard you shouldn't have to worry.
Old 05-04-2003, 01:20 PM   #5
Herminator's Avatar
Send a message via ICQ to Herminator
just run the car around a bit, the glue soon wears off, you need to scrub the tyres in anyway to get rid of the release agent from the mold.
Herminator is offline   Reply With Quote
Old 05-04-2003, 01:28 PM   #6
are you using slicks or treads calvan ng?
Old 05-04-2003, 01:45 PM   #7
Registered User
Calvin Ng's Avatar
yeah im using slicks
too late i used the alchol
didnt do anything because my mom told me acetone is way stronger then it. she's a chemist
removing 1/18 shocks rcjustforfun Rookie Zone 3 05-16-2007 11:36 PM
removing tire from rim lachlan90 Nitro On-Road 10 02-08-2004 03:28 PM
removing tire from rim lachlan90 Electric On-Road 8 01-20-2004 02:27 AM
Removing CA Calvin Ng Electric On-Road 1 08-03-2003 11:54 PM
removing CA from tire Calvin Ng Electric On-Road 1 05-04-2003 12:47 PM
