Old 07-28-2009, 03:29 PM   #781
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Anyone try the new TC5X chassis and top deck from EXOTEK?
http://www.exotekracing.com/EXOTEK_N...6/29_TC5X.html
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 07-28-2009, 03:37 PM   #782
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Yes, it works great on asphalt.
IIGQ4U is offline   Reply With Quote
Old 07-29-2009, 10:01 AM   #783
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Originally Posted by Kajman View Post
Anyone knows how about flex in offroad? Should it be more or less? Everyone talks about asphalt, how about rally cars? Some people here use tc5 and tc4 for it...
Kajman - the reason we talk about asphalt here is because this is the onroad section of the forum. . . you could start a thread over on the offroad section. . .
I love rally - I actually race rally in full-size cars (Dodge Neon makes a great 2WD class car) so it might be fun to play with rc rally cars but off-road tracks have too many jumps for rally. . . :/
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 07-29-2009, 10:24 AM   #784
Kajman's Avatar
Well, offroad is treated as for buggies and 1:8 vehicles mostly, here in Central Europe we have quite strong onroad rally class competitions where we use onroad cars like f.e. TC5, Xray and so on.
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 07-29-2009, 11:04 AM   #785
Trader Rating: 27 (100%+)
Send a message via AIM to John Stranahan
I had quite a discussion on a previous thread looking for cases where a full size car might need more flex. It turns out that racing on dirt is the case. On asphalt more stiffness is usually desirable in full size. The fellow talked about choosing a space frame chassis that by chance had a little more flex in roundy round racing. Oval on dirt, sprint cars I believe.
So yes the RC dirt car can be easily made too stiff. A TC4 having much more flex might be an improvement over the TC5 chassis wise. Unfortunately that extremely responsive solid shaft driveline might be less desirable than the double belt. A XXXS with the long belt should be ideal. I would set up a TC5 with high flex, ITF, for rally racing. On dirt you need very smooth inputs to the tires to hold traction.
[email protected]
TeamCRC.com Mikes-HobbyShop.com
John Stranahan is offline   Reply With Quote
Old 07-29-2009, 02:57 PM   #786
antonio_cadiz's Avatar
hello!
i want balls bearings for wheels tc 5 but the team associated are very bad.
the measures is 6x10x4 mm Where buy other more good?.
sorry for my english
thanks
antonio_cadiz is offline   Reply With Quote
Old 07-29-2009, 03:03 PM   #787
Originally Posted by antonio_cadiz View Post
hello!
thanks
hi!
they are 6x10x3mm, you can look at ebay or stores.
Btw, IMHO asso bearings are very good, just clean and oil it
I use my asso set 4x and after this I drop some to trash
Regards!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 07-29-2009, 04:24 PM   #788
Guys, there is no difference in performance between delta and wye winds. The difference between the two are kv related. A Neu 1515 1D motor has a kv of 4100. A 1515 1y has a kv of 2200. The main reason for using one wind over the other is to target a certain kv. Wye winds are usually favored over deltas becuase they are more tollerant to timming advances. Deltas work best at low timming, advancing the timming on a delta only generates more heat and not performance. Hope this helps.
Mark
MarkF is offline   Reply With Quote
Old 07-29-2009, 04:28 PM   #789
Kajman's Avatar
That is not that simple. True, that same kv Y and D will be similiar. But f.e. GM and CS Electronic motord delta work best with 30deg timing. People say Y is more efficient, but in case of above mentioned delta are more efficient (over90%) than Y. So story is hard to explain
Old 07-29-2009, 05:00 PM   #790
Antonio- Look at a set of these. They have rubber seals. Our wheel bearings fail from two causes, dirt entry (get the rubber seals) impact with the boards (buy plenty of bearings till you quit hitting the boards). These are four packs.
they also have an ultra seal which has a very small gap that limits dirt entry.
http://bocabearings.com/main1.aspx?p...CWK106-2YS_NB2
Buena Suerte
[email protected]
Old 07-30-2009, 04:53 AM   #791
hello!
very thanks to M.Abramowicz and John Stranahan
bye.
Old 07-30-2009, 09:10 AM   #792
You are welcome.
Here is pic of the top strap with dimensions layed on. I checked these wigth a dial caliper.
Associated Factory Team TC5, Brushless, LiPo, Li-ion Nanophosphate, Tips and Tricks-top-strap-swivel001.jpg
[email protected]
Old 07-30-2009, 06:03 PM   #793
Heat Control Continued
My touring car is in good condition to run in the heat with a 3.5 now. Things that I did. I added Novak's largest capacitor to the Tekin RSPro speed control. I installed a homemade fan made from a pinion to the armature of the LRP X12. I made it a centrifugal fan (like a blower) rather than an axial fan like a home/ shop fan. I have one electric fan left to cool it. It was 98F today although the track was only 117F. Things were quite cool after a 6.5 minute run. The hottest was one part of the speed control on the bottom at 160F. It has its own fan which blows on the solder posts.
Novak Internal Fan cooling Kit Eagle Racing, Integy
Now I wanted to duplicate this setup or improve it with more store bought items and less handwork. I bought a Novak internal fan kit made by Eagle Racing imported by Integy. It has a tiny axial fan that mounts on the tapered part of the pinion side of the armature. I used red high temperature loctite and tapped it in place with a guide. A small steel cylinder from my Hyperdrve bearing installation tool. It did not want to go on square, but with a little more work it was fairly true. Now the kit is imported so all the instructions are in chineese with few diagrams. The kit also has a nicely ventilated endbell, silver colored. The fan and endbell fit the ballistic series of motor with the stock armature. There was good air exit paths now, but nowhere for air to get in the motor. I made two large vents that match those in the stack at the back. You can see one in the photo. I then mounted the integy heatsink and fan. This will help by blowing air into the back of the motor. The armature fan will direct it forward and out and hopefully will stay in place. I have my doubts. Anyway, mostly storebought but some handwork needed. Speed passion does sell a 3.5 with an internal fan as an optional armature. The Speed Passion can is well ventilated. The Speed Passion would be the lowest effort route.
Note that the rear endbell comes right off the back of the motor so the holes are made with no danger to the windings.
The Fantom 3.5 advertized at Stormer with an internal fan did not have one. I sent it back.
I narrowed the blue heatsink by one row.
Associated Factory Team TC5, Brushless, LiPo, Li-ion Nanophosphate, Tips and Tricks-cooled-novak-ballistic-3.5.jpg
[email protected]
Old 08-17-2009, 05:58 AM   #794
dsyed1's Avatar
has anyone tried nitride bearings on the tc5? for example http://www3.towerhobbies.com/cgi-bin...&I=LXSHU2&P=ML
dsyed1 is offline   Reply With Quote
Old 08-22-2009, 09:01 AM   #795
Trader Rating: 19 (100%+)
John,
Have you though about powering the fans on a seperate (small) lipo packs?
I though about using a small lipo like this.
http://www.hobbycity.com/hobbycity/s...Ah_2S1P_15-25C
Using three yeah racing fans. Two on the motor and one on the esc.
http://www.youtube.com/watch?v=muH9TVsbNjY
zake540 is offline   Reply With Quote
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 11:26 AM
BRUSHLESS rc18t factory team with lipo dub599 R/C Items: For Sale/Trade 11 06-16-2008 12:14 AM
Factory team B4 Novak brushless with lipo PTP Racing R/C Items: For Sale/Trade 1 12-13-2007 11:36 PM
Factory Team RC18T with hopups and brushless / lipo setup! Cain R/C Items: For Sale/Trade 5 11-26-2007 05:35 PM
Xray T2R, 2100 mah 2c LiPo, and Mabuchi power: Tech tips and Tricks gacjr0 Electric On-Road 46 11-18-2007 10:09 AM
