Old 08-08-2007, 01:14 AM   #16
Originally Posted by BlackedOutREVO View Post
Well I have a question
When looking at FDR's does a lower, say 4.50 ratio mean that the car would be faster with less torque to like 5.0, and vice versa?
So pretty much the smaller the numbers, the more speed?
Im getting all confused, I was recomended a ratio between 4.50 and 5.0 and im looking at a FDR sheet from gear chart, and im looking to see which spur will work best with the pinions I have, to get the ratios I want
Yes
Not trying to brush you off but you can always ask someone like Harshguy at SWR. They are a wealth of knowledge.
Sydewynder is offline   Reply With Quote
Old 08-08-2007, 01:19 AM   #17
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by Sydewynder View Post
Yes
You can always ask someone like Harshguy at SWR
Im talking to Russ..... Javier doesnt post as much as Russ
But thanks
BlackedOutREVO is offline   Reply With Quote
Old 08-08-2007, 01:23 AM   #18
Im talking to Russ..... Javier doesnt posy as much as Russ
But thanks
Cause Javier is old
Old 08-08-2007, 01:29 AM   #19
Cause Javier is old
Old, but hes fast!
lol
U race at swr?
Old 08-08-2007, 08:57 AM   #20
Trader Rating: 16 (100%+)
I like to run rubber tires cause I don't have to concern about rollout that much...but can someone please give me some ball park figure if I want to run foams.....what is the stock brushed rollout suppose to be..? And what about 13.5 brushless...?
If I am running foams...do I still need to know FDR? Or use rollout # only..? Thanks...
Old 08-08-2007, 07:38 PM   #21
wog....supraman's Avatar
Send a message via MSN to wog....supraman
i have made programs for all this on my graphix caluclator...Top speed, wheel circumference, FDR, rollout, gearing...and more....2 find rollout....just get your wheel diameter and Pi it...then divide by your FDR.
e.g
63mm X Pi = 193mm (in my head) / 5.96 (my ratio)=aroud 33.2
easy
wog....supraman is offline   Reply With Quote
Old 08-08-2007, 10:17 PM   #22
e.g
easy
http://gearchart.com/index.cfm?fuseaction=chart.create
Does it all for you, You just type in the info lol...... Alot easier IMO
Old 08-08-2007, 10:32 PM   #23
RussB's Avatar
Send a message via MSN to RussB
But thanks
dang, how are you posting for me in a thread i haven't posted in before?
RussB is offline   Reply With Quote
Old 08-09-2007, 12:00 AM   #24
I have super powers
Old 08-09-2007, 06:06 AM   #25
HarshGuy's Avatar
Cause Javier is old
Old and bitter
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 08-10-2007, 02:17 PM   #26
RussB's Avatar
I have special powers
fixed.
Old 08-10-2007, 02:29 PM   #27
fixed.
Haha
Ok fine... That works I guess
Old 08-10-2007, 02:51 PM   #28
Originally Posted by HarshGuy View Post
Old and bitter
Just kidding with you. You can beat me up next time you see me.
Old 08-10-2007, 02:55 PM   #29
As if
He still hasnt gone through with a harsh take out he said I had coming
Old 08-20-2007, 03:29 AM   #30
echo's Avatar
I use 415MSX with spur 102, tire diameter 58 (foam) track layout high speed, i use peak 19T.. what the best rollout for high speed track?
I am a Human Network
echo is offline   Reply With Quote
Calculating roll out jnor R/C Tech Site Forum 5 04-10-2007 02:46 PM
Calculating milliamps rockdog200 Electric On-Road 3 07-24-2006 09:25 AM
calculating stuff fritzD Electric On-Road 3 09-11-2005 03:18 PM
Having a tough time calculating rollout. EDWARD2003 Electric On-Road 3 07-24-2005 11:59 AM
Calculating Speed jigga21 Electric On-Road 11 12-29-2004 10:24 PM
