novak gtb esc false temp shutdown >
Old 08-05-2007, 12:12 AM
Default novak gtb esc false temp shutdown
i have a novak gtb esc that shut down at 12-130 f , i have tried two diffrent motors on this esc but same shit happens . any who know if i can turn off the temp sensor on the esc
tomin is offline
Old 08-05-2007, 02:14 AM
bxpitbull's Avatar
Default Get the Novak black fan
My Novak fan (the stocker that came with it) is missing a tooth and basically, is on its last legs. For the first time, I thermalled! It happened at 136 degress. I am running a taller gear ratio (9.375) on a 3.5, but I wanted blistering speeds (thank you car action speed run!). If your ratio is tooo tall for your motor, expect thermals. I read on another post somewhere, that the Novak black fan is much stronger, lessening chances of thermals on the speedo. In addition, cut a hole or two in the body (like nitro) to get that extra cooling. I ran a body with no holes, taller gearing and I thermalled...everything that is against my grain...but I had to try it. And if anyone wants to know, my motor hit 136 degrees...well into its safe zone.
bxpitbull is offline
Old 08-05-2007, 03:01 AM
did a little test now and the esc dont shutdown with my 4.5 motor , and the 3.5 motors dont shutdown with my 4.5 esc
tomin is offline
Old 08-05-2007, 03:34 AM
bxpitbull's Avatar
WHAT????
Old 08-05-2007, 03:51 AM
SWTour's Avatar
..so if we read that right - you have 2 systems.
One GTB w/ a 3.5 and one GTB with a 4.5
You switched the motors, and used them with the other speed controls and the problems didn't occur? (Wa- La - sounds like you fixed it)
Could there have been something...from ESC Mounting or gear MESH causing the original combination to generate too much heat prematurely?
SWTour is offline
