Old 05-03-2003, 03:11 PM   #1
stoopidbstrd's Avatar
Send a message via AIM to stoopidbstrd
Default how do i...
get my glued tires off the rims without cutting them?
i know i have to put them in some liquid but which liquid do i use?
thanks
stoopidbstrd is offline   Reply With Quote
Old 05-03-2003, 03:18 PM   #2
RedScorp's Avatar
Send a message via ICQ to RedScorp Send a message via AIM to RedScorp Send a message via Yahoo to RedScorp
Acetone or Nail Polish remover. But if you have plastic rims, the rims will be destroyed...only nylon rims will hold up to acetone and polish remover.
RedScorp is offline   Reply With Quote
Old 05-03-2003, 03:34 PM   #3
im guessing most tamiya rims are plastic huh?
well thanks.
Old 05-03-2003, 05:34 PM   #4
how long would it take if i use nail polish remover?
Old 05-03-2003, 05:54 PM   #5
newracer's Avatar
R/C Tech Charter Subscriber
you can also boil them
newracer is offline   Reply With Quote
Old 05-03-2003, 07:35 PM   #6
popsracer's Avatar
Default Removing Tires from the Rims
stoopidbstrd
As newracer said BOIL them. Put them in a 4 quart Sause Pan and cook then on simmer for a few hours. Rinse them in cold water and crack the bead to remove the tires.
I'd stay away from the Acetone unless I'm trying to save the Rims and know what kind of Plastic they are made of.
popsracer is offline   Reply With Quote
Old 05-04-2003, 08:51 AM   #7
traxxasdude's Avatar
you can also put them in the oven, but lots of times this can ruin the tires but has a better chance of getting the tires off.
traxxasdude is offline   Reply With Quote
Old 05-04-2003, 09:08 AM   #8
davioh's Avatar
Default Re: Removing Tires from the Rims
Originally posted by popsracer
stoopidbstrd
so just put them in boiling water? and whats simmer?
davioh is offline   Reply With Quote
Old 05-04-2003, 10:06 AM   #9
Trader Rating: 69 (100%+)
boiling works i do this whenever i have relatively new tires and a wrecked rim. i have an inexpensive water heater that you plug in ac power then dip it in a bucket of water. when the water starts boiling (after about 5 to 10 minutes), i put the tires & rims in for about half an hour. then i dip it in tap water until theyre cool to hold. the tires are easily removed but it helps to have a blade cutter to clean up the rim and tire. then i reuse the tire on a new rim
i think "simmer" means to set the stove to low heat after the water boils. the water will still be hot but not boiling anymore.
marvi is offline   Reply With Quote
Old 05-04-2003, 10:25 AM   #10
popsracer's Avatar
Default Simmering Tires and Rims
Simmer = Lower the Heat after the water boils. This is to keep the Water from evaporating so quickly. Also It helps to keep the Pan covered. (and DO NOT add Salt)
Old 05-04-2003, 11:08 AM   #11
can i steam them? (or maybe add some hot sauce?)
anyway thanks for the answers guys, but seriously will them come off if i steam them?
Old 05-04-2003, 11:09 AM   #12
one more thing, should the water level be higher than the tires?
and would it have any bad effects on the tires, rims, and foams?
Old 05-04-2003, 02:22 PM   #13
ok i just got my tires and foams off the rims by boiling them. that worked fine. but now my rims are bent (actually they arent my rims). anyway, is there a way to get the tires off without damaging any of the other parts?
Old 05-04-2003, 02:27 PM   #14
try to put them in boiling water again but this time use something to keep the rims flat.
Old 05-04-2003, 02:49 PM   #15
i see. thanks
