i need help fats please.
hey guys,
i just came from my LHS and bought 2 battery's and a speed control for my F103 LM the battery's are charged and the remote is at full power... now heres my problem ... i connected all the wires and turned everything on and try to test it out before going outside and nothing happened... so i moved the wires from ch. 1 to ch.2 and so forth and still nothing, but when i touch the antenna to the reciver wire the car goes hay wire going to forward and reverse with no control input from me, and the steering servo wont turn either... i went with what my LHS suggested i get , i have the traxxas Tl-1 ESC and a venom 3300 NIMH battery
any help would be great thanks
sorry ESC IS XL-1
si the esc setup for your radio???? do you have the wires going to the reciever the right way??
Are the connectors in the reciever the correct way around?
Ian
Ian
yes i have a futaba magnum 2pl and the wires are in the right way they wont go in the other way ... and im running the tamiya black can ... idk if that makes a difference...
hahahah i feel like an idot , i had grabbed the wrong reciver i grabbed teh 27 hertz not the 75 herts
okay guys so i have a prophet charger from dynomite and it wont charge my battery, it just keeps beeping .... any ideas?
check your fuse. could have gone bad or gotten damaged.
yea that charger is a POS .... for some reason the two fueses they gave me in the box Blew and i bought more 7.5 amp fuses(the eact same) and blew 5 of those , so im just giving up with this charger and gonna get the intelli peak seeing that it does 1-4 amps not just 1,2,4 amps....thnaks for eveyones help
Word of advice, get the Intellipeak ICE, get that and you'll never need another charger.
