Spool - One way - Diff
A Spool is a solid axle, helps with mid corner and corner exit power and steering.
You can get one-ways for most cars.
Diff's are generally only used for carpet/foam setups
Despite it's description and the fact it seems mad to have a locked front axle, almost all the top guys on asphalt will be running spools.
Skiddins
Skiddins
do they ever run spools in the reaqr as well?
I think if you put a spool in the rear, it will make your car slower when in corners for it is like a locked axle so when you turn, they are having a hard time turning for when you turn, the rear's wheels is not turning an equal turn...
For example, you turn right, the left side of the rear wheel will turn more and create little gap than the right rear wheel and vice versa... For the rear wheels dont steer... Not like the front... Hope you get what I mean...
spool up front all the time.
xanavi spool is useless for the rear it will just result to oversteer and i mean OVER
Originally Posted by oversquared
if ever you do get the right setup it wouldnt be slow . if memory serves me right solid rear axle is being used in 1/8th GP cars and heck theyre FAST
Try to time your runs with a rear spool and vice versa, see what your time would be if having the spool at the rear and vice versa... If you made it faster with a spool at the read, then I would just say..... Bravo...
is car with one way set up will be faster than a car using spool or diff at front???
If it has intermediate to hard braking zones (a track with a technical infield) try a spool.
The two are very different to each other, (and different to a diff up front) so be sure to take a few practice laps with each if you have not used them before!
