First time to run it >
Old 08-03-2007, 02:04 AM
Default First time to run it
Hi guys this would be my first time to run modified using a checkpoint 7x1 motor. how should i gear it?
and what is the timing for? the more i advance it? the more i retard? by doing so will affect my final drive gearing?
please help.
thanks
oversquared is offline
Old 08-03-2007, 04:41 PM
anyone?
Old 08-03-2007, 09:46 PM
mo
mo's Avatar
Not much information to go by so I'll assume your running it in a touring car on a medium size asphalt track with rubber tires. I would set the timing at 10-12 degrees, probably how it was set in the package, and gear it around 9.0:1.
mo is offline
Old 08-04-2007, 02:55 AM
hello mo. I will run it in tamiya USa track. it is the track where the recent reedy race was held.
so 9.0 with 12deg is the starting line? thanks
more info are welcome
