tamiya 11T mod gearing >
Old 05-03-2003, 05:57 AM
davioh's Avatar
Default tamiya 11T mod gearing
im gonna go buy this motor tommrow along some pinions, what should i gear it at? (evo3)
internal gear ratio - 2.2
current spur - 96T
pinion- what should i get?
64 pitch
davioh is offline
Old 05-03-2003, 07:17 AM
jedi's Avatar
Your internal ratio is 2.6 not 2.2. you should use a 35 tooth pinion for a small track and a 36 tooth pinion for a big track. Set the motor timing at about 12 degrees.
jedi is offline
Old 05-03-2003, 07:42 AM
davioh's Avatar
2.6! sorry my bad...forgot isn't 2.2 ta04's? mighta got them mixed up. the track is really big, for nitro's so yea. i might get like 36-38's
...i currently hav a 39. i'll give that a shot to
davioh is offline
Old 05-03-2003, 08:32 AM
jedi's Avatar
You will burn your motor. a 37 is as high as you can go but even that is pushing it. The 36 works best on a long nitro track.
jedi is offline
Old 05-03-2003, 08:50 AM
davioh's Avatar
oh okay. thanks...you seem to b an evo 3 user?
davioh is offline
Old 05-03-2003, 06:12 PM
jedi's Avatar
Yes I am. Love it for stock and 19t but find the drivetrain a little to fragile for open mod motors.
jedi is offline
Old 05-03-2003, 06:54 PM
davioh's Avatar
have you tried the type RR? how does it compare to the 11T mod?
davioh is offline
