Old 05-03-2003, 02:07 AM   #1
Registered User
Default Reedy Kr Motor???
Where have Reedy Kr Motor in stock? Is it out yet?
Aku-Man is offline   Reply With Quote
Old 05-03-2003, 02:43 AM   #2
MauiBuilt Racer's Avatar
It's out right now. For sure Hobby People has them in stock.
MauiBuilt Racer is offline   Reply With Quote
Old 05-11-2003, 03:02 PM   #3
Mr. MR4's Avatar
I am currently using the Krypton 10 x1 with this setup
Orion 2/6 Silver Brushes
Standard Springs
5 Degrees Timing
Final Ratio 6.92
The motor runs fine but the only problem is that the brushes become blue after every run with hardly any comm wear.
Anyone else had the same problems???
Mr. MR4 is offline   Reply With Quote
Old 05-11-2003, 03:19 PM   #4
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
That could be related to the % of silver content in those brushes making them heat up. Iím not personally familiar with those Orion ones but Iíve talked to people who have 3-4 runs on the stock ďActronĒ brushes without a problem.
MarkA is offline   Reply With Quote
Old 05-11-2003, 03:28 PM   #5
Mr. MR4's Avatar
Hi Mark,
Thanx for your input.
I used the same set up with the actron brushes too and had the same problem.
I also tried 3 Degrees timing and went up a couple of teeth in gearing - but it wasn't as fast.
The motor seems to be geared properly and is very consistant throughout the race and gives me plenty of runtime.
Old 05-11-2003, 04:36 PM   #6
Moderator
MarkA's Avatar
Idea for you to try then: Bump the timing up, something like 12-18+ degrees, and gear down a tooth or two on the pinion. That will put the motor into the high-end RPM power band that it likes for more of a lap. Your low-timing setup with more gear could be making it lug along and any sort of bogging (even if maybe itís not immediately noticeable) will definitely heat up the brushes.
Old 05-11-2003, 07:29 PM   #7
Hobby People doesn't have the motor on their site. Does anyone know who else has this motor in stock?
rcpilot is offline   Reply With Quote
Old 05-11-2003, 09:53 PM   #8
Moderator
MarkA's Avatar
Stormer has a few of the winds in stock at: http://www.stormerhobbies.com/cgi-bi...ASC0&man=Reedy
Hobby People has a few winds in at:
http://www.hobbypeople.net/mfr/assocd01.asp
Old 05-11-2003, 09:56 PM   #9
STLNLST's Avatar
my LHS has them in stock.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-11-2003, 10:05 PM   #10
mike_Webb's Avatar
Send a message via AIM to mike_Webb
I heard that you should just stick with the 766 Brush...it is the same brush that come with and performs very well in the Reedy Ti motors but it is the laydown version.
mike_Webb is offline   Reply With Quote
Old 05-12-2003, 01:02 PM   #11
Thanks Mark.
Old 05-12-2003, 01:09 PM   #12
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I just picked up a MR-4TC SD SSG and that will be my motor of choice for the car. Anyone have idea on what I should start the gearing at? I will be using 64 pitch gears.
Old 05-12-2003, 02:14 PM   #13
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Mike Webb, yes the 766 is the same as the 729 Quasar just laydown. I'd suggest staying with the 766 as i've heard stories of burning brushes with any significant silver content (e.g. 767's).
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 05-12-2003, 05:25 PM   #14
BTW, I am plannin on running a 8 turn double.
Old 05-12-2003, 06:18 PM   #15
Umm...track size plays a large role....ask people you know what they are gearing their 7 turns (Ti's) and that should be about right.
USVTA Member #211
FS: MTRONIKS GENESIS TRUCK B/L ESC, FEIGAO 380C-6L MOTOR & REEDY NEO-ONE 4 STAR MOTOR davidrrr R/C Items: For Sale/Trade 5 08-16-2008 03:32 PM
reedy motor echo Electric On-Road 4 05-21-2007 06:43 AM
Reedy Mod Motor 20 SMOKE R/C Items: For Sale/Trade 6 12-10-2006 07:00 PM
New Reedy KR motor TheTurtleMan R/C Items: For Sale/Trade 2 03-30-2006 08:08 PM
reedy motor monstermatt R/C Items: For Sale/Trade 1 05-28-2004 08:04 AM
