Old 08-03-2007, 09:40 PM   #31
For any one who is willing to spend good money on a quality product these buttons are the bomb!!! Alot of work went into these to make sure you could achieve an accurate balance on your car. If you want to cheap it out go rite ahead, but most of us will support the companies that revolutionize R/C!!!
Good Luck Guys
mulherin is offline   Reply With Quote
Old 08-06-2007, 08:33 PM   #32
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
every so often,you buy a product amd you smile when you get it cause its so cool,and works so well......
that's what happened to me......these buttons are great........even better,I found out my pro 4 was only 21 grams out of wack with a lipo......
I encouarge every one to pick up a pair......
always remember,to race RC....
you need Balls!!!!!!!!!!!!!!!!!!!
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 08-06-2007, 09:42 PM   #33
SlamMan's Avatar
I've got to say this is one of the more ingenious products I've seen in a while. Kinda makes you say "why didn't I think of that".
You'll never be able to make everyone happy though. That's the Internet and it will never change. A good company like IRS with good products will overcome that stuff without so much as a hiccup though.
SlamMan is offline   Reply With Quote
Old 08-07-2007, 07:24 AM   #34
fastharry,
Glad you like the Balance Buttons. I like your last comment.
When starting to use the buttons, set you car on them and hold it level then release it and find out which way it tips. You then need to move you electrics around and hold it level again and see if it tips to one side again. Sometimes you have to add small lead weights to finish balancing your car. Do this till the car sets level on the Balance Buttons. When done tip the car to either side and make sure it tips at the same rate and you are done. You should find that your car will need less loading on the tweak screws or springs to get the car neutral.
Dave
Diffdude is offline   Reply With Quote
Old 08-07-2007, 07:29 AM   #35
SlamMan,
You are right! I just got tired of it. I quess it is a case of, putting mouth into motion before putting mind into gear, on their part. We as an industry do try to make available to the racers quality products at a fair price but like you said you can't make everyone happy.
Thanks for your support.
Dave
Old 08-07-2007, 09:17 AM   #36
Here is a new tip for the balance buttons. To keep them in place on the chassis while working on it put a dot of diff lube between the chassis and balance buttons. This will allow you to pick up the car and make adjustments.
Dave
Old 08-07-2007, 11:34 AM   #37
When are they going to be available in the uk?
Smoking motor.. is offline   Reply With Quote
Old 08-07-2007, 12:14 PM   #38
Smokin motor,
Our products are available anytime on our web site, TeamIRSrc.com
It will be about $22.00 for Global Priority shipping.
Dave Irrgang
Old 08-07-2007, 01:16 PM   #39
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Dave - you still make the best stuff, hands down
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-07-2007, 02:22 PM   #40
Thanks Kaybo. Hope to see at one of the tracks over the winter.
Dave
Old 08-07-2007, 02:58 PM   #41
k_bojar's Avatar
Dave
And which track would that be?? the way they are dropping around here, I'm not sure how much carpet racing we'll be doing this winter
Old 08-15-2007, 08:32 AM   #42
fastharry™'s Avatar
guy.....I just wanted to let you know,I took the balls out last night for some tues night racing.......
I have to say,they were the hit of the night........everyone was amazed how Accurate they were........cars that are balanced stand right up....yet,put a 7 gr weight on the side,and the car tumbles....there is no uncertainty like the pin balancers(like when they appear that the car is stuck in the middle,yet you know the car is unbalanced...)...
plus,they are way easier to use....no having to find the sweet spot on the pins.....
they were realy well liked.........
Old 08-15-2007, 08:41 AM   #43
RCSteve93's Avatar
I can't wait until my stuff comes from IRS, I ordered a set of these with my order.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 11-15-2007, 04:50 PM   #44
Jack Smash's Avatar
Trader Rating: 29 (100%+)
I dont seem to be having the same results as the rest of the guys. There is a bit of a flat spot on the ball where the pin is interted and the car kinda gets "stuck" on this keeping the chassis level. Takes quite a bit of weight to get the car to trip over this and fall over. Anyone else having this issue?
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 11-15-2007, 06:06 PM   #45
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Another guy at my track had that same issue. He found a solution, but I can't remember what it was . . .I think it ahd to do with raising on end or tilting it to get it to rest in front of or behind the flat spot where theres a true hemisphere.
To Balance or Not to Balance Lipo Packs while charging RED-LINE M03 Electric On-Road 14 10-24-2007 05:00 PM
LiPo Charge Balance / Non-balance bugnet Electric On-Road 2 09-12-2007 07:39 AM
To Balance or Not to Balance Lipo Packs while charging RED-LINE M03 Electric Off-Road 25 09-04-2007 02:22 PM
1/12th scale SlapMaster Tools MS2.3 fjm9898 R/C Items: For Sale/Trade 17 05-21-2007 12:37 PM
FS: Tools, Tires, Batteries, TC3 Parts and Electric Tools jlee777 R/C Items: For Sale/Trade 7 03-24-2005 02:56 PM
