HOT ESC
Old 07-30-2007, 12:59 PM
xrs_wtf's Avatar
Default HOT ESC
Ok i'm having an ESC problem i think, I bought some venom-racing 5000mah NiMH battery packs, since i'm having longer/harder run times, my ESC is heating up BAD. I have to let it cool down which is no big deal, but after that about 5 mins later its shutting down again, now do they make some kinda of fan or something to put over top of the heatsinks..? or should i just buy a new ESC, cause i been looking at the Novak XRS, as an upgrade. What do you guys think i should do here, any help, or links would be greatly appreicated.
FYI: the ESC is a Hawk reversible from Nosram, also it's for a 17turn motor.
Thanks guys/gals
xrs_wtf is offline
Old 07-30-2007, 01:30 PM
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Yup, you can mount a small 6volt fan over or blowing across your ESC
Upgrading to a better ESC won't help because you are really working that ESC with that much run time.
minicooper is offline
Old 07-30-2007, 01:35 PM
minicooper's Avatar
example: http://www2.towerhobbies.com/cgi-bin...1p?Q=&I=LXJUR6
Old 07-30-2007, 03:14 PM
razzor's Avatar
or gear down a pinion or two.Might be working a tad too hard.
razzor is offline
Old 07-30-2007, 03:50 PM
xrs_wtf's Avatar
I dunno all the gearing is stock from the factory, though it may be a possiblity..???
xrs_wtf is offline
Old 07-30-2007, 04:03 PM
What car and motor is it?
InspGadgt is offline
Old 07-30-2007, 04:24 PM
Xanavi_R34's Avatar
possible facts:
How many turns do you run with that esc?
What's is your FDR (Final Drive Ratio)?
How long is the straight in your track, maybe your gearing is too much or not enough when it reaches the end of the straight...???
Xanavi_R34 is offline
