Touring Car Foams for Dummies
Hi,
I searched but found nothing. What is the difference between: magenta Cyan Plaid Purple indigo Which ones are harder or softer? |
1. Magenta is softer than purple. It offers the most traction of those listed.
2. Cyan is a Magenta with a thin harder ring of foam on the outer edge. 3. Indigo is a Magenta with a slightly softer ring of foam on the outer edge, as compared to a Cyan. More bite than Cyan, less than Magenta. 4. Purple is harder than Magenta. 5. Plaid is a Purple with that thin hard ring of foam on the outer edge, just like the Cyan. |
http://www.shopatron.com/index/137.0...2133.22137.0.0
If you look at the Colors - Purple, Cyan etc... there is a corresponding number next to it. This is called a shore rating. Basically , the higher the shore number, the harder the compound. Usually the higher the shore number is for higher grip surfaces, lower number for lower grip. |
the cyan's and things are good but I would go with Jaco foams. I run (most people who runs jacos) double pink orange in the front and double pink in the rear. cyans etc are compatable but I am use to jaco's so I run them more than aything.
