Ko propo EZ-1000 esc >
Old 07-22-2007, 07:34 AM
edwintklee's Avatar
Trader Rating: 23 (96%+)
Default Ko propo EZ-1000 esc
EZ-1000
Simple plug & play esc .
EZ-1000 (#40024)
http://www.kopropo.com/ESC.htm
Simple plug and play ESC designed to handle more than 15T motors. CPU controlled with forward and reverse. 32x33x21.1mm size, weight 39.8g, Maximum Peak current/Forward 400A, Reverse 200A, Continuous Electric Current/ Forward160A, Reverse 80A. Operating input voltage: 7.2V-8.4V
i have 1 only running sliver cans,
how good is it?
any1 try to go lowest turn???
is it ok to run 19t motor on this esc???
thank for all feedbacks..
edwintklee is offline
Old 07-22-2007, 09:03 AM
as written on specifications you can run up to 15 turn motors on that esc, you shouldnt have any problems running 19ts. cheers!!!
imel24 is offline
