This Dean/Tamiya Adator Ok to charge batteries? Picture! >
Old 07-21-2007, 10:23 PM
Default This Dean/Tamiya Adator Ok to charge batteries? Picture!
I very new to electric and there are so much to learn than I thought.
Anyway, I have a peak charger with the regular tamiya plug. But my batteries have deans plugs on them. So I soldered an adaptor with a dean plug on one end and a tamiya plug on the other. Does it look correct and ok to charge the batteries like that? Or do I have to ditch the tamiya plug on the charger and direct solder a dean plug on the charger?
EWsome is offline
Old 07-21-2007, 10:40 PM
UN4RACING's Avatar
Trader Rating: 22 (100%+)
You should just take the dean plug off the jumper and solder it to the lead off the charger. With the Tamiya your more likely to get a false peak.
The deans have a much better connection.
UN4RACING is offline
Old 07-21-2007, 11:38 PM
But I have other batteries with the regular tamiya plug for the EZ Start and Roto-Start that I need to charge also.
EWsome is offline
Old 07-21-2007, 11:47 PM
That will work fine as long as you make sure that the positive and negative polarities are correct from the charger thru the adapter to the battery.
calvin is offline
Old 07-22-2007, 01:27 AM
mkiiina's Avatar
Trader Rating: 71 (100%+)
will work fine. i use the same when im swapping between my truck and gfs TC. no ill effects thus far!
mkiiina is offline
