Which is Quicker 5 or 6 cell? >
Old 07-19-2007, 06:55 PM
  #31
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by Marcos.J View Post
have you run 5 cells?? I run 5 cells and you dont have to gear really crazy, only 2 or 3 teeth more on the pinion, i also ran 5 cells with the 10.5 at our last carpet race and it was pretty fast and my gearing wast too far off the 6 cell guys with the 10.5
i want to try this with my brushed stock
could be my experement
a 5cell pack, and a 6 cell pack, and comapare lap times
how much more gearing should i put on to my CO 27? i have 3 more gearing options, so i gan gear up 3 more teeth on what pinions i have
BlackedOutREVO is offline
Old 07-19-2007, 07:14 PM
  #32
PitCrew's Avatar
No, I have not run 5 cells yet. I plan to run 5 cell mod very soon.
Nice to hear your results. Did you add weight so your car weighed the same as the 6cell cars?
I wonder why everyone keeps asking "HAVE YOU RUN 5 CELLS?" like it changes the laws of physics or something....
Funny thing is the guys jumping on my case are the 5 cell supporters.....with whom I am basically agreeing with.
I think its a cool idea, as long as its legal to have the car weigh less. Otherwise the power to weight ratio isn't there. Oh I better not get started again.
Just one question. How does a 12th scale mod make 8 mins if 6cell mod touring cars only make 6mins at best?
PitCrew is offline
Old 07-19-2007, 07:27 PM
  #33
Trader Rating: 35 (100%+)
smaller minute of inertia and less drag.
Sean R is offline
Old 07-19-2007, 07:44 PM
  #34
Super Moderator
Marcos.J's Avatar
Trader Rating: 217 (100%+)
i didnt add any weight to the car if you run 5 cells your allowed to run a minimum weight of 1450, im at 1463 with the body (51.6 ounces)
Marcos.J is offline
Old 07-19-2007, 07:46 PM
  #35
Super Moderator
Marcos.J's Avatar
thats what i did , ran 3 heats on a saturday with 5 cells went home changed the car to the 6 cell chassis then sunday i ran 3 more heats with 6 cells, and i was faster on saturday
Marcos.J is offline
Old 07-19-2007, 07:52 PM
  #36
PitCrew's Avatar
sweet.
I don't doubt you can get around the track faster with 5 cells vs 6. The car should work better. As long as its balanced.
Maybe I should have run 5 cell at paved nats in stock. Maybe I would have won.
PitCrew is offline
Old 07-19-2007, 07:57 PM
  #37
Super Moderator
Marcos.J's Avatar
sweet.
maybe who knows!!
Marcos.J is offline
Old 07-19-2007, 08:02 PM
  #38
PitCrew's Avatar
probably not.
My car was on rails anyway.
2nd is ok with me.
PitCrew is offline
Old 07-19-2007, 09:31 PM
  #39
i ran out front, motors stays really cool! runs nice!
but the batt is brand spanking new, so idk, but i THINK that im still udergeared with 3 extra teeth... because *about* 90- 100% throttle is the same speed.. no incrase at all, even off the ground, so im going to try and get these batts run a few times before tomarow, im going to charge, dis charge to 1.2 volts per cell (like my normal runs) and then charge, then repeat a few times
then run it another once or twice, and then race it
but so far, i like it, i might have to gear up more, so idk yet, i need practice time, but if i get killed, then thats what happens....
marcos, how much did u gaer up ur stock motor? i think a few more teeh for me mite be in need, BUT i have to wait and see what cycling the batt does first
Old 07-19-2007, 11:22 PM
  #40
This isn't a fair test because you are running the same setup for both.
Example: a dialed 6 cell setup could be garbage with 5 cell.
You would need to find an optimal setup for 5 cell and 6 cell and then you could compare them.
Sean R is offline
Old 07-19-2007, 11:28 PM
  #41
Trader Rating: 87 (100%+)
Have any of you tried 5 cell modified on carpet w/foams? I wonder if the same weight rules will carry over?
Thanks in advance.
RBLove is offline
Old 07-20-2007, 01:18 AM
  #42
true
very true
i will find out tomarow, i will see what needs changing to be fast on 5cell
Old 07-20-2007, 08:33 AM
  #43
Super Moderator
Marcos.J's Avatar
same set up all i did was the chassis change
Marcos.J is offline
Old 07-20-2007, 12:35 PM
  #44
rc-zombies's Avatar
true
very true
5 cell chassis... mine is coming a week or so..
rc-zombies is offline
Old 07-20-2007, 03:05 PM
  #45
haha thats what u ordered over seas?
im going at 4:30 to see what i can pull outs this brushed motor lol...... so we will see if i can drive it somewhat fast, if i can keep up with the experts assuming im racing with them) then i will stay 5 cell till im bl and all that
because i know for shure that i could use less power through turns and all so i dont need brakes
how much was it? i just dont know how well batt soldering will be, i have to run mine in the back because i use deans
lmk when u are racing again zombies, i want to see all this new stuff u have
