Old 07-18-2007, 06:00 AM   #1
Superkarter's Avatar
Default Charger Problems
I have a Eagle Racing CDC Version 6.0/b Charger and when I plug a battery on to it after connecting it to the power supply, it shuts the power supply off like itís a short. If I connect the battery to the charger before turning the power supply on it turns on and appears normal, but when you start charging on the charge screen the mAh counter doesnít start counting and the battery voltage doesnít change.
Does anyone have any ideas or has anyone come across this before
Superkarter is offline   Reply With Quote
Old 07-18-2007, 07:42 AM   #2
Xanavi_R34's Avatar
this you should remember... never use your batteries as power supply (to power up your charger or else)... I think one of your fuses exploded already, kindly check fuses and change them if necessary... your charger will really on when you plug first the battery but this can damage your charger, so please, as much as possible, never plug in the batts first...
Xanavi_R34 is offline   Reply With Quote
Old 07-18-2007, 07:51 AM   #3
GymBeam's Avatar
what power supply is it? not a computer PS is it???
try powering your charger with your 12v car battery.
GymBeam is offline   Reply With Quote
Old 07-18-2007, 08:14 AM   #4
Xanavi_R34's Avatar
yeah, also kindly check the input of your charger...
Old 07-18-2007, 04:55 PM   #5
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
same thing happened to my CDC Version 6.0/b.. it doesnt charge.. but can discharge..
nikkiesteban is offline   Reply With Quote
Old 08-19-2007, 05:48 PM   #6
did anyone figured out why did this thing happened???
it doesn't charge any the counter for mah doesn't count and the voltage isn't increasing.. so it does not put any charge in the batts.. but the discharge function is working...
hello miss, puwede pa bind?
Duratrax Ice Charger Problems Associated-08 Electric Off-Road 10 04-05-2008 09:34 AM
Much More Cellmaster Charger Problems noline Electric On-Road 0 02-18-2008 07:25 PM
Charger Problems After Getting Deans waterblast02 Electric On-Road 9 06-28-2006 05:39 PM
Please help. Battery charger problems. J_ROD48 Rookie Zone 4 05-22-2006 09:02 PM
Charger Problems Need Help NoahTheBoa Rookie Zone 5 01-23-2006 09:46 PM
