How to remove strip anodized color? >
Old 07-17-2007, 07:33 AM
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default How to remove strip anodized color?
Any one have any suggestions on how to safely and easily strip anodized color from small parts without damage?
I have a couple small parts that dont match the rest of the car and I wanted to strip them back to silver.
Jamie
J.Gonzalez is offline
Old 07-17-2007, 07:38 AM
rcarmchl's Avatar
Trader Rating: 15 (100%+)
Easy Off will do it....
rcarmchl is offline
Old 07-17-2007, 07:54 AM
J.Gonzalez's Avatar
From what I have heard that can damage/pit the part. Any less aggressive options?
Thanks for the help
Jamie
Old 07-17-2007, 08:02 AM
TeamButter's Avatar
greased lightning will work as well. Not sure how abrasive it is though.... I know someone who used it on their Schuie bulkheads and it worked great.
TeamButter is offline
Old 07-17-2007, 08:31 AM
I have used this on many anodized aluminum RC car parts with great success. I chose not to use the Easy Off as I also heard that it can cause "pits" in the metal. If you use Greased Lightening, just pour enough into a glass bowl to cover the part. Let it sit for 10-15 minutes, check the part and flip it over if needed. Then, remove the part from the bowl and rinse it off with water. After drying the parts off, I would recommend using a product called Mothers Mag & Aluminum Polish to give the parts a nice shiny chrome-like finish. It works very well.
Hope this helps.
needrcspeed is offline
Old 07-17-2007, 09:18 AM
If its hard anodized, nothing short of dynamite will remove it.
Regular anodization will come off with Easy-Off, but it will pit aluminum
if left on too long. The trick is to keep an eye on it. Be sure to wear gloves
too.
qwkpony is offline
Old 07-17-2007, 10:19 AM
vtl1180ny's Avatar
too.
For hard anodizing (or any) I use their Anodizing & chrome stripper... http://www.caswellplating.com/kits/aluminum.htm It's made up in a 5 gallon pail with a lid and I have it made for whenever I'm doing any metal refinishing...
vtl1180ny is offline
Old 07-17-2007, 11:44 AM
stuey's Avatar
Hope this helps.
can you get this in the uk and wear.
stuey is offline
Old 07-17-2007, 12:41 PM
Jamie
Some anodizing shops will do it as a part of their preparation process. I have a shop locally that will do that.
-E
THE DARKSIDE is offline
