Speedpassion Brushless.
#856
thermal
I run my GT yesterday in pretty hot conditions with a 3.5 sp motor.
I would thermal at around 4 minutes with 5 cell.
If i turn off the thermal cut off how much of a difference will it make has anyone tried it yet?
thanks
thanks
#858
Were you running the fan? Id be supprised if you could get it to thermal with the fan on with 5 cells.
#859
Sadly, MRT's is still a way off.
How much can the timing be changed with the GT's?
Skiddins
#860
gearing
Has any body tried it with the cut off off.
#863
Regional Moderator
I had seen a lot of people talking about Speedpassions stuff, but I had no idea what they were talking about.
Then I just got the SchumacherUSA newsletter yesterday....wow! That speed control is pretty sweet. Is it smaller than the LRP Spere or about the same size? I guess I could just compare the size specs, but I'm feeling lazy right now.
#864
It is not the GT. This one is from the manufacturer. Speed Passion is a distributor and have the products branded under their name. The one I have does handle 4S, I tired it already, but before I even go that high, I want to see how it does on 2S and 3S first. I will also run this controller on my 1/8 truggy to see if really does put out what it claims.
#865
R/C Tech Elite Member
44mm X 36mm X 18.5
#866
Yes its the same in appearance to hobbyWing Xerun but Speedpassion version has better software and programmer as well as having better quality hardware.
#869
You might be a little wrong on this. The Xerun handles 4S lipos and has a burst of 720A. The program box is the same, but Speed Passion just wanted some other stuff written differently. Keep in mind that Speed Passion is a distributor and they can have items branded with their logo. I can have the same as well, but why should I brand something that is not mine.
