Closed Thread
Old 01-08-2008, 05:53 AM   #796
Send a message via MSN to makytc4
Originally Posted by Ian S View Post
Mine did this when I hadn't set up the neutral, throttle high point and brake high point properly.
Are you running sensored or sensorless?
set up sppedo as of manual. th highpoint 100. th curve 0, th brake 100. says in manual to put throttle on stick to reverse before reset in manual. running sensored with orion 10.5 tried different motor made no difference tried going to 40mhz made no difference
makytc4 is offline
Old 01-08-2008, 06:02 AM   #797
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Victor Vector View Post
Piece o' cake !! Installed, programmed with Richie's numbers.
Bugged that the sensor loom is soooooo short. I plonked the speedo in with the sensor plug on the inside of the car to make the motor wires short, only to discover the non stretchability of that loom.
And them signal wires are sooooooo long!!
Damm, I'm just tooooo fussy.
Sounds teriffic zooming round the toy room. Testing Weds night at Big Dads.
Jacko
longer senor wires are available from SP or
grab a senor wire off a LRP motor, had to do that for the B4.
skypilot is offline
Old 01-08-2008, 06:28 AM   #798
Ian S's Avatar
Sorry I dont understand this bit.
The procedure is:
1) Turn on the speedo with the setup button pressed
2) Realease the button when it starts to beep and then press the button again to store the nutral point
3) go to full throttle on the transmitter and press the button to store throttle high point
4) go to full brake/reverse on the transmitter and press the button to store the brake high point.
If this is what you have done and it still has a problem then it may be a faulty unit.
Team Schumacher UK
Ian S is offline
Old 01-08-2008, 07:20 AM   #799
Victor Vector's Avatar
Major rebalance needed as the SP set up is 33 gr lighter than the ol' Novak kit !!
Jack Balchin.
Timezone Hooligan
IBEW Local 48-retired (Definitely, great pension.)
Victor Vector is offline
Old 01-08-2008, 07:22 AM   #800
abailey21's Avatar
Trader Rating: 36 (100%+)
I'm not trying to sound negative or direct, but the proper procedure is in the directions included with the box. I did it last night and mines fine today.
The procedure is:
K.C.C.O.
abailey21 is offline
Old 01-08-2008, 08:24 AM   #801
AdrianM's Avatar
Those are the instructions from the user's manual....just translated from Engrish to English
Adrian Martinez
AdrianM is offline
Old 01-08-2008, 09:36 AM   #802
Ian S's Avatar
Adam - Im not trying to sound too blunt or anything but im the one GIVING the help
I had the same problem as someone else and am describing the set-up procedure in slightly easier to underatand english.
Team Schumacher UK
Ian S is offline
Old 01-08-2008, 10:11 AM   #803
abailey21's Avatar
Paul (Mutley) Schumacher UK DOES have Speed Passion speed controls and motors in stock and shipping, give them a call.
Ian, sorry man, I misread that Thanks
Were working on the instructions by the way
K.C.C.O.
Old 01-08-2008, 10:40 AM   #804
The procedure is:
yeah followed completely. the bit i mean is where it says a) switch off the esc turn on the transmitter set the direction of throttle channel to reverse
maybe i shouldnt have put the channel in reverse did everybody else do this
makytc4 is offline
Old 01-08-2008, 10:47 AM   #805
mutley001's Avatar
Thanks Adam, Phoned them this morning too but they said they didn't! guess they mudt have arrived after I phoned! Will try again.
Thanks for your efforts Adam
Paul
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline
Old 01-08-2008, 11:03 AM   #806
mutley001's Avatar
Nope, just phoned them again, and the motors are in the country but in customs! Oh well, just have to wait I guess!
Looking forward to running it though if all reports are true!
Cheers
Paul
ARC R11 2017
ARC R10 2013
Team EAM
Old 01-08-2008, 11:05 AM   #807
lutach's Avatar
That is for Futaba radio. I used my Spektrum in Normal not reversed, followed the easy calibration and was done.
lutach is offline
Old 01-08-2008, 11:13 AM   #808
ahh that would make a lot of sense ill try that now
makytc4 is offline
Old 01-08-2008, 11:28 AM   #809
Send a message via ICQ to MattW
KO radio needs to have throttle channel reversed - trust me on this one
MattW is offline
Old 01-08-2008, 11:58 AM   #810
cant get it to do it know only wants to do it when the cars under load. also tried taking the capactitor see that was to fault didnt make a difference
makytc4 is offline
Closed Thread
For Sale Speedpassion 5.5 brushless motor Marcos.J R/C Items: For Sale/Trade 1 08-24-2008 06:36 PM
Speedpassion GT Brushless ESC -- Great Deal or8ital R/C Items: For Sale/Trade 3 07-17-2008 05:06 PM
For Sale: Speedpassion GT Brushless Speedo, 13.5 and 10.5 L.Fairtrace R/C Items: For Sale/Trade 4 04-04-2008 01:36 PM
For Sale Speedpassion 2.5 brushless motor Marcos.J R/C Items: For Sale/Trade 6 03-22-2008 06:10 PM
For Sale Speedpassion 10.5 brushless motor Marcos.J R/C Items: For Sale/Trade 2 03-03-2008 05:52 AM
