Closed Thread
Old 12-29-2007, 08:55 PM   #571
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
I got my GT all Loaded into my car but cant use it until Wednesday...... The adjustments are easy to do now lets see how it works on the track.
Speedpassion Brushless.-rc-bodies-007.jpg   Speedpassion Brushless.-rc-bodies-008.jpg
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline
Old 12-29-2007, 09:03 PM   #572
Shawn Palmer's Avatar
We'll be getting in the Speed Passion Super Caps with our next order. 4cell and 6cell versions.
Shawn Palmer
Speed Passion USA Sales Manager
USAsupport <at> King-Golden <dot> com
www.SpeedPassion.net
www.SpeedPowerrc.com
Shawn Palmer is offline
Old 12-29-2007, 09:14 PM   #573
Applesauce's Avatar
Trader Rating: 14 (100%+)
Shawn,
When do you think that will be?
Applesauce is offline
Old 12-29-2007, 11:54 PM   #574
Trader Rating: 37 (100%+)
Nice Kev. Too bad you will miss the Warm-up race. If you want I will let you know the settings I ran that day to give you a comparison and hopefully a headstart for Novak!
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline
Old 12-30-2007, 01:52 AM   #575
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Shawn . . .
you have any information about caps in that bottomless well of R/C electronics knowledge? Something along the line of appropriate values for varying demands, or perhaps high quality vs. low quality vs. size vs. cost along with some name brands an off brands?
For example I know the original spheres came with a very small cap, but now te TC spec and all the GTB's have a much larger cap. Are there higher quality caps that are smaller or is there always a direct relationship between size and cap capacity?
I know caps are rated somehow and usually a higher number means a bigger cap, but thats about where my understanding stops.
There is no substitute for understanding!
-CG-
andrewdoherty is offline
Old 12-30-2007, 02:01 AM   #576
http://www.racingfactory.fi/shop2/ca...atalog.php?c=6
Are these the caps y'all are talking about getting in soon? They look like they aren't cylindrical . . .?? Like maybe flat?
Old 12-30-2007, 02:01 AM   #577
razzor's Avatar
Andrew hope this helps.
http://www.kinggolden-rc.com/doc/Spe..._June82006.htm
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline
Old 12-30-2007, 07:53 AM   #578
Anybody run their GT ESC w/ the SP 10.5R this weekend? Any tips on settings or you running default.
Or running the GT ESC w/ a Novak 13.5.
Nexus is offline
Old 12-30-2007, 10:03 AM   #579
JayBee's Avatar
Trader Rating: 31 (100%+)
I'll be out today with it buddy, I'll have something for ya
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline
Old 12-30-2007, 03:52 PM   #580
Hi guys,
Sorry I know this has been asked before but I'm still confused
Will a SP 3.5T will work with Novak GTB? I mean the sensored cable included with the Speed Passion motor will work on the GTB ESC??
thanks, got this SP 3.5T on the way and really anxious if it'll work!!
Associated TC4 FTB44 FTT4
Kyosho Lazer ZX5 "hop uped"
Novak GTB 5.5r & GTX
Kyosho MP777 RB S7
Kyosho Mad Force (needs work) and Minium cessna
Jammin CRT.5 SH .12 turbo engine
Traxxas S-Maxx
Yokomo World SD replica (500 items only)
Schumacher Rascal (needs new tank)
Losi Micro-t
CEN Nemesis (needs radio)
....perhaps a little addicted??
Loverc is offline
Old 12-30-2007, 04:00 PM   #581
AdrianM's Avatar
Originally Posted by Loverc View Post
Hi guys,
It will work perfectly. The plugs on all sensor harneses are standard. Your GTB (or LRP Sphere, GM Genius, etc...) will run any brand of sensored motor as long as the sensor wire is connected.
Adrian Martinez
AdrianM is offline
Old 12-30-2007, 06:23 PM   #582
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Today I had my first runs with the GT and Sp 10.5 motor on my Cyclone...
Gearing: 5.18FDR Temps: 141F after 6 min heat.
results: well, set it up with the zero timing and #6 throttle profile. The car was fast and had good low end. In 2 heats today, It had real good low end, but down the straight it wasnt as fast as the the others guys like the BOwser Brothers, Tim K., D. Batiste, etc, who were running mostly Novak. That was the only issue..I needed a bit more top end...almost there!!( my driving didnt help)
1) Gearing: The gearing tells me I can try one more tooth on the Pinion, but the temps will get higher...I like the 10.5 motors to run in the 140-145F range, and the Novak and Orion 10.5 i have tried performed real well at those temps and were a bit faster than my SP 10.5 today...
2) ESC settings: I can try using timing on the ESC, maybe 3.75 deg option or something else...if anyone has played with this please let us know what timing gives the best result. Incresing the throttle profile from 6 to 7 or 8 might do it, but this might also increase temps, as it happens w/ LRP Sphere TC. I dont mind getting 160F temps as long as it wont kill the motor...
Any other suggestions?
Anyone run GT and SP 10.5 today? What setings did you use and what FDR and how did it fare against other systems?
yyhayyim is offline
Old 12-30-2007, 06:28 PM   #583
Gone Racin's Avatar
Default SP
Hello Guys, My son Austin ran the SP 4.5 and the 10.5 today on a fast big track.Ran 4.5 with same FDR and ESC settings, new CS 27 the same for all 3 motors. 4.5 was overall much Faster than are other mod motors we ran. The 10.5 was just fast. Blows out all other 10.5 in my opinion. We tested 4different type of 10.5 motors. PW setup, EP 4600, All in All great propuct. Thanks Ron Harrison,
Gone Racin is offline
Old 12-30-2007, 06:29 PM   #584
AdrianM's Avatar
If you ran Zero timing (AMTS Setting #1) you were way under timed and probably under geared. I ran my Novak 10.5 at 4.8 FDR and it didnt get too hot.
I would leave the gearing the same (5.18) as start walking the timing up to the default setting of #6 (18.75*). Don't worry about temps until you get close to 180*F.
Adrian Martinez
AdrianM is offline
Old 12-30-2007, 06:30 PM   #585
AdrianM's Avatar
What motor timing setting did you use?
Adrian Martinez
AdrianM is offline
Closed Thread
For Sale Speedpassion 5.5 brushless motor Marcos.J R/C Items: For Sale/Trade 1 08-24-2008 06:36 PM
Speedpassion GT Brushless ESC -- Great Deal or8ital R/C Items: For Sale/Trade 3 07-17-2008 05:06 PM
For Sale: Speedpassion GT Brushless Speedo, 13.5 and 10.5 L.Fairtrace R/C Items: For Sale/Trade 4 04-04-2008 01:36 PM
For Sale Speedpassion 2.5 brushless motor Marcos.J R/C Items: For Sale/Trade 6 03-22-2008 06:10 PM
For Sale Speedpassion 10.5 brushless motor Marcos.J R/C Items: For Sale/Trade 2 03-03-2008 05:52 AM
