Closed Thread
Old 12-28-2007, 09:45 PM   #541
skypilot's Avatar
Trader Rating: 14 (100%+)
i should have came home and waited, someone sent it insured and i have to sign for it, no biggie, working the weekend anyway
skypilot is offline
Old 12-28-2007, 09:50 PM   #542
corallyman's Avatar
Trader Rating: 99 (100%+)
Adam or Shawn,
I have a few more questions for you guys. I hope you don't mind.
1. The GT supports sensored or sensorless motors, does the speed control come with a sensor wire, if so what is the length?
2. If the GT does not come with the sensor wire, do the SpeedPassion motors come with it? If so what is the length?
3. Do all SpeedPassion motors come with Sintered rotors, if not which do and which motors don't?
4. Will you guys bring in the 90mm sensor wires that speedpassion sells?
Thanks a bunch.
Steve
corallyman is offline
Old 12-28-2007, 10:04 PM   #543
abailey21's Avatar
Trader Rating: 36 (100%+)
Skypilot, I told you to go home man
Steve;
The speed control does not include a sensor wire, all of the motors come with them.
It will run sensored or sensorless motors, it will also run sensored motors without the sensor cable (I did it with my 13.5 this evening)
The sensor cables are 90mm (look at the pic of my car to see it), we also have optional 190mm cables for off road applications.
All motors are sintered if they are purchased through Schumacher US, if you went with anyone else you stand a good chance of having and earlier release and I don't know what those rotors might be?
We will also sell the 90mm sensor cables by themselves in the coming weeks (they're on order)
K.C.C.O.
abailey21 is offline
Old 12-28-2007, 10:12 PM   #544
corallyman's Avatar
Thanks Adam, you guys are Top notch. Give yourself a pay raise.
Steve
Old 12-28-2007, 10:17 PM   #545
Trader Rating: 37 (100%+)
This Speed Passion Grand Turisimo ESC has got to be the easiest one in the world or atleast my world to program.
The handheld unit is so straight forward. No blinking lights to follow while you try to stab some tiny a## button.
Anyway I got mine mounted and played around with everything. Just having the handheld and an easy way to reset the profiles is awesome.
The fan seems to move way more air the the stock Novak clear ones. Reminds me of the Nexus Racing fan I used to run. They move the air pretty good wired stock. I know some guys wire the fan straight to battery power which spins them faster. I'm not sure this fan even need that. Also from the some of the early input many guys are not even using fans.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline
Old 12-28-2007, 10:51 PM   #546
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Has anyone ever "accidentally" run a Sphere or a GTB or a SP GT without the coffee can cap? Why is the cap there? I know "warranty blah blah blah", but would a 13.5 run efficiently or even at all without the cap? Novak said at one time I think that it helped reduce esc temps, but my esc never gets hotter than 100* running a 13.5 and a10.5 on carpet/foams . . .just wondering ..
andrewdoherty is offline
Old 12-28-2007, 11:55 PM   #547
AdrianM's Avatar
From my understanding the cap is there to help keep the incoming supply voltage up during huge current spikes. Even mild BL motors like 17.5 and 13.5 can draw a lot of current on start up. This current spike drives the pack voltage down...especially late in a run of if you run utill you dump.
If the supply voltage gets too low the gate voltage for the FET transistors gets low and bad stuff starts to happen.
The cap also helps keep your speed control's BEC voltage up so you dont lose power to your rx and servo under the same high current drain conditions.
So...do not remove the caps
Adrian Martinez
AdrianM is offline
Old 12-29-2007, 01:13 AM   #548
razzor's Avatar
Some setup and programming info i got from Speedpassion.
Hope this helps.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline
Old 12-29-2007, 01:16 AM   #549
JayBee's Avatar
Trader Rating: 31 (100%+)
ALL DONE!!!
I figured since Adrian liked the first install....here's another one A
Speedpassion Brushless.-sp-gt-install-2.jpg   Speedpassion Brushless.-sp-gt-install-3.jpg
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline
Old 12-29-2007, 01:49 AM   #550
razzor's Avatar
Setup and test info for GT esc.
File Type: doc SpeedPassionMotorandGTESC_Suggestion_Dec22nd2007.doc (139.0 KB, 293 views)
Casterracing ZX1.5R
razzor is offline
Old 12-29-2007, 05:28 AM   #551
aittam's Avatar
Hi all,
just got a couple of questions regarding both the Fegaio and the GranTurismo ESCs.
Do they handle lipo?
Do they have some kind of lipo cut-off feature?
Thank you.
Mattia.
aittam is offline
Old 12-29-2007, 05:36 AM   #552
abailey21's Avatar
YES, and YES
Originally Posted by aittam View Post
Hi all,
Thank you.
Mattia.
JB or as Doug calls you "parts box".....your purple wire makes me happy
Now I was running a speed control back in the day (one of those antique brushed only ones) and I did a bad solder job on the cap and it came undone while driving and it was that first speed control from that particular company I EVER blew up, and I ran assorted different models for 10 years from them.
K.C.C.O.
Old 12-29-2007, 05:37 AM   #553
abailey21's Avatar
Will you tell Robin, and Shawn that...
Steve
K.C.C.O.
Old 12-29-2007, 06:52 AM   #554
Tim Kowal's Avatar
R/C Tech Charter Subscriber
I believe the instructions say the fan runs at battery voltage connected to speedo, no need to hook it up direct.
TEAM ASSOCIATED - REEDY - J CONCEPTS - RC3 GRAPHIX - KOOL AID - TEAM P-NUT MOTORSPORTS.COM - SUPERIOR HOBBIES.COM
Tim Kowal is offline
Old 12-29-2007, 08:03 AM   #555
abailey21's Avatar
It does, I don't remember verbatim what it says, but it's something to the effect of that same voltage of battery power.
Verbatim from the manual.....
The voltage of fan socket on the ESC is equal to the voltage of the battery, it is directly supplied without any regulation, so please keep in mind that the voltage of the batttery CANNOT over the voltage limit of the fan.
K.C.C.O.
Closed Thread
For Sale Speedpassion 5.5 brushless motor Marcos.J R/C Items: For Sale/Trade 1 08-24-2008 06:36 PM
Speedpassion GT Brushless ESC -- Great Deal or8ital R/C Items: For Sale/Trade 3 07-17-2008 05:06 PM
For Sale: Speedpassion GT Brushless Speedo, 13.5 and 10.5 L.Fairtrace R/C Items: For Sale/Trade 4 04-04-2008 01:36 PM
For Sale Speedpassion 2.5 brushless motor Marcos.J R/C Items: For Sale/Trade 6 03-22-2008 06:10 PM
For Sale Speedpassion 10.5 brushless motor Marcos.J R/C Items: For Sale/Trade 2 03-03-2008 05:52 AM
