Digital Servos
Old 07-16-2007, 03:03 AM
Nuno Gancho's Avatar
Default Digital Servos
Hi guy´s, what digital servos are the top driver using, what torque and speed should the servo has for a touring car. Thanks. it is for 5 cells modified race.
Nuno Gancho is offline
Old 07-16-2007, 03:19 AM
rampal's Avatar
get either the futaba s9550 or the KO Propo PDS-2413ICS. Both are low profile speed around 0.12 and 0.10 and torque around 8.5 kg. Many pros are using them (including me, but I'm not a pro... )
cheers,
al
rampal is offline
Old 07-16-2007, 12:42 PM
I agree. I am not a pro, but using the ko 2413ics and it is very good!
rcnewb2004 is offline
Old 07-17-2007, 05:33 AM
bozla's Avatar
Yeah, definitely go with futaba.
bozla is offline
Old 07-17-2007, 05:37 AM
alecladanga's Avatar
futaba s9550
alecladanga is offline
Old 07-17-2007, 06:25 AM
Trader Rating: 81 (100%+)
+1 for the futaba 9550
i recently replaced my erg-vrx with a 9550 on my BD, freed up a lot of space for easier esc & rx mounting the specs are just right for touring car application. also consider the KO low profile servo, it has slightly better specs than the 9550
marvi is offline
Old 07-17-2007, 08:03 PM
bmmer701's Avatar
Trader Rating: 17 (100%+)
+1
i used both servos and i like KO better
bmmer701 is offline
Old 07-17-2007, 08:09 PM
TL_XXX-S_racer's Avatar
Go with the Futaba 9550. While i was at the nats, there were many pro drivers using this servo. Its flawless, and very reliable. I havent had a problem with it.
TL_XXX-S_racer is offline
Old 07-18-2007, 04:16 AM
Originally Posted by bmmer701 View Post
+1
hey bmmer, swap my 9550 for your KO
marvi is offline
Old 07-18-2007, 04:43 AM
ROBORAT's Avatar
many of the servos out there have very high torque and speed ratings ... but many will say these are too much anyway for ep touring car applications.... even the pros. as you will notice, many of the pros use the 9550 and i think the KO low profile servo is catching on as well and it isnt making them any slower than other pros out there. surikhran won the worklds with a 9550 and i believe so did rhienard. lemiuex placed 3rd in last year's worlds with a 9550 as well. no doubt there are other servos with better ratings but obviously they dont really mean you need them.
ROBORAT is offline
Old 07-18-2007, 06:02 AM
rampal's Avatar
Andy Moore uses the KO 2413, Paul Lemieux the Futaba s9550... two very good drivers with both
rampal is offline
Old 07-18-2007, 06:21 AM
Trader Rating: 27 (100%+)
JR 8800S (my fav) or the KO listed.
convikt is offline
Old 07-18-2007, 08:55 AM
|JayFlores|2's Avatar
Trader Rating: 16 (100%+)
i am still using the s9451, from stock to mod without any problems
|JayFlores|2 is offline
